03-09-2016, 13:20
#1 (permalink)
Join Date: Mar 2009 Location: YT - Channel RealFix-GRS.TV Age: 37
Member: 990711
Sonork: 100.1597405 Thanks Meter: 1,779 | Y511-U251 (FLASHING) PartCount : FFFFFFFF Y511-U251 (FLASHING) PartCount : FFFFFFFF
PHONE STATUS HANG LOGO
AFTER THIS ERROR PHONE IS DEAD
HELLO TEAM YOU HAVE SOLUTION THIS PROBLEM Quote:
Operation : Flash [ v1.42 ]
======= Flash
Wait for phone...
Phone found! [ 13 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048602A46BD081E1
Initialize Memory ...
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048602A46BD081E1
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 4AE9C57EFC221BD7ED37EE156D9F4CC9
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : wt98511 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3810 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98511.bin
Preloader Sent , Init passed
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:00:57
Reconnect Power/Cable! | Quote:
============ Memory Detection Report =========== Internal RAM:
External RAM:
Type = DRAM
Size = 0x20000000 (512MB/4096Mb)
NAND Flash:
ERROR: NAND Flash was not detected!
EMMC:
EMMC_PART_BOOT1 Size = 0x0000000000200000(2MB)
EMMC_PART_BOOT2 Size = 0x0000000000200000(2MB)
EMMC_PART_RPMB Size = 0x0000000000200000(2MB)
EMMC_PART_GP1 Size = 0x0000000000000000(0MB)
EMMC_PART_GP2 Size = 0x0000000000000000(0MB)
EMMC_PART_GP3 Size = 0x0000000000000000(0MB)
EMMC_PART_GP4 Size = 0x0000000000000000(0MB)
EMMC_PART_USER Size = 0x00000000e7000000(3696MB)
UFS:
ERROR: UFS was not detected!
============ RAM Test ============
Data Bus Test:
[D0]
[D1]
[D2]
[D3]
[D4]
[D5]
[D6]
[D7]
[D8]
[D9]
[D10]
[D11]
[D12]
[D13]
[D14]
[D15]
[D16]
[D17]
[D18]
[D19]
[D20]
[D21]
[D22]
[D23]
[D24]
[D25]
[D26]
[D27]
[D28]
[D29]
[D30]
[D31]
OK!!
Address Bus Test:
[A1]
[A2]
[A3]
[A4]
[A5]
[A6]
[A7]
[A8]
[A9]
[A10]
[A11]
[A12]
[A13]
[A14]
[A15]
[A16]
[A17]
[A18]
[A19]
[A20]
[A21]
[A22]
[A23]
[A24]
[A25]
[A26]
[A27]
[A28]
OK!!
RAM Pattern Test :
Writing ...
0x44332211,
0xA5A5A5A5,
0xA5A5A500,
0xA500A500,
0xA5000000,
0x00000000,
0xFFFF0000,
0xFFFFFFFF,
OK!!
Increment/Decrement Test:
Writing...
OK!! | |
