01-16-2017, 15:45 | #1 (permalink) |
Freak Poster Join Date: Oct 2015 Location: eArTh
Member: 2470191 Status: Offline Sonork: 100.1652036 Thanks Meter: 308 | HUAWEI GR3(TAG-L21) dead boot Repair done by great Cm2 HUAWEI GR3(TAG-L21) dead boot Repair done by great Cm2 Rejected by some Baglool shop keepers not done with their fake tools Code: Wait for phone... Phone found! [ 49 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741BB320705212081D0 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050732BBD0811321 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0xCFCD2027B167611E3201B872C82BA883 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 179A BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 179A PartTable Init Ok , Count : 19 All Done Done! Elapsed: 00:00:09 Reconnect Power/Cable! rsa7262 |
The Following 15 Users Say Thank You to rsa7262 For This Useful Post: |
01-26-2018, 18:33 | #8 (permalink) |
Major Poster Join Date: Feb 2017 Location: BENIN
Member: 2689292 Status: Offline Sonork: solevo Thanks Meter: 3 | Chinese Miracle II [MTK module] v 1.58 User selected Preloader file : preloader_hexing6580_we_l.bin Operation : Init Preloader [ v1.58 ] Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 110100303038473730 , Name : 008G70 , Vendor : 11 , [TOSHIBA] FlashID [2] CID : 450100445332303038 , Name : DS2008 , Vendor : 45 , [SANDISK] FlashID [3] CID : 450100445331303038 , Name : DS1008 , Vendor : 45 , [SANDISK] FlashID [4] CID : 700100563130303038 , Name : V10008 , Vendor : 70 , [KINGSTON] FlashID [5] CID : 700100454838434538 , Name : EH8CE8 , Vendor : 70 , [KINGSTON] FlashID [6] CID : 150100463732324D42 , Name : F722MB , Vendor : 15 , [SAMSUNG] FlashID [7] CID : FE014E50314A39354B , Name : P1J95K , Vendor : FE , [MICRON] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 57 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 70010045483843443401135A17729357 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xC40B0000 EMICFG_RET_FAILED CodeDefine : DA_DEVICE_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:28 Reconnect Power/Cable! help me |
04-17-2018, 11:03 | #10 (permalink) |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Dear Sirs, If you have good flash files and if you want to share it with other users please use IOS File Uploader Tool Please do not upload password protected or damaged files, all of them will be deleted after upload. Thank you ! |
09-26-2018, 09:02 | #13 (permalink) |
Freak Poster Join Date: Mar 2018 Location: Kharian Age: 43
Member: 2826140 Status: Offline Sonork: 1644958 Thanks Meter: 103 | Supported HW by Preloader : TAG-L21 Boot repair Don FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 19 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 484A019065324741BB100705AB082380 Initialize Memory ... DRAM configured from ScatFW! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e2GA [eMMC] : FLASH_CID : 90014A4841473265050710BB802313AB [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB800000 [eMMC] : FLASH_UCP : 15032 MiB [eMMC 16 GiB] DEV RID : 0x90494A4E218AA5ED5D06C876C6E1E628 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 179A BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483847316505 , Name : H8G1e , Vendor : 90 , [HYNIX] FlashID [1] CID : 90014A484147326505 , Name : HAG2e , Vendor : 90 , [HYNIX] FlashID [2] CID : 150100513331334D42 , Name : Q313MB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 13014E52314A39364E , Name : R1J96N , Vendor : 13 , [NOT_IN_BASE] FlashID [4] CID : 110100303136473332 , Name : 016G32 , Vendor : 11 , [TOSHIBA] BL : Storage supported by BootLoader! Sending BootLoader ... Preloader Sent , Init passed SecCfg Passed , 179A PartTable Init Ok , Count : 19 All Done Done! Elapsed: 00:00:13 Reconnect Power/Cable! Thanks |
The Following User Says Thank You to gsmkharian For This Useful Post: |
