05-24-2016, 13:24 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: INDIA Age: 38
Member: 269044 Status: Offline Sonork: 100.1590584 Thanks Meter: 3,949 | Huawei honor hol-u19 virus remove and read flash done with cm2:- Code: Operation : Check / Read Info [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3858564D420678E0D49B9177 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D420678E0D49B9177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 97F0E2F0EBB0431E6FF65486D0B4D1C1 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : Hol-U19 ProdModel : Hol-U19 Device : HWHol-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : Holly-U19V100R001C583B105 SECURITY : IMEI_SW [1] : 86611202xxxxxxx IMEI_SW [2] : 86611202xxxxxxx BTMAC Addr : 38F889BAB357 WiFi MAC : 38F889B7A617 MODEM : BaseBand : MT6582_S00_MOLY_WR8_W1315_MD_WG_MP_V51_1_wg_n EXTRA : LCD [0] : hx8394a_hd720_xinli_at803 LCD [1] : nt35521_hd720_dsi_vdo_dijing LCD [2] : r61318_hd720_xinli_at803 LCD [3] : dummy_lcm LCD Res : 1280x720 TOUCH [0] : GT9XXS CAM [0] : s5k4h5yx_mipi_raw CAM [1] : ov8858_mipi_raw CAM [2] : gc2235_mipi_raw CAM [3] : hi258_mipi_yuv CAM [4] : hi258_mipi_yuv_shengtai CAM [5] : #gc0329_yuv MODEM : huaqin82_wet_b2b_kk_hspa_2014_8_25 LOCALE : en_US Done! Elapsed: 00:00:37 Reconnect Power/Cable! VIRUS REMOVE Code: Operation : Scan APPs [DDirect] [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3858564D420678E0D49B9177 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D420678E0D49B9177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 97F0E2F0EBB0431E6FF65486D0B4D1C1 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! USBDL : Init HSUSB Ok DDirect : Init Ok! Scanning FileSystem now , please wait Collect and verify data according Dictionary Collect done : 0x0006 [DDCleaner Info] : Files to remove : 23 [DDCleaner Info] : Additional garbage detected : 17 Removing files ... [DDCleaner] : Removed 23 Special Op #1 : Clear Recovery Data Ok! Special Op #2 : Clear UserData Ok! Special Op #3 : PostFix Ok! All Done! Done! Elapsed: 00:01:17 Reconnect Power/Cable! READ FLASH Code: Operation : Read Flash [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 1501004B3858564D420678E0D49B9177 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x15 , OEM : 0100 [eMMC] : FLASH_INF : [SAMSUNG] , BMVX8 [eMMC] : FLASH_CID : 1501004B3858564D420678E0D49B9177 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003A3E00000 [eMMC] : FLASH_UCP : 14910 MiB [eMMC 16 GiB] DEV RID : 97F0E2F0EBB0431E6FF65486D0B4D1C1 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! Brand : HUAWEI ProdName : Hol-U19 ProdModel : Hol-U19 Device : HWHol-U AndroidVer: 4.4.2 MTKxCPU : MT6582 MTKxPRJ : Holly-U19V100R001C583B105 [Read Ok] : preloader_huaqin82_wet_b2b_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6582 / V1.1.1 / huaqin82_wet_b2b_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 1307 MiB Scatter saved to : C:\Users\NASA\Desktop\huawei holly\MT6582__HUAWEI__Hol-U19__HWHol-U__4.4.2__Holly-U19V100R001C583B105\ All done! ALL THE OPERATION WORKED FINE AND THE PHONE IS ALSO WORKING FINE BUT WHEN I CONNECT TO CM2 IT SHOW PreLoader : NOT Active [ Erased ] WBR sahil2000ind |
