06-17-2019, 16:55 | #1 (permalink) |
Freak Poster Join Date: Feb 2009 Location: Nigeria
Member: 974244 Status: Offline Thanks Meter: 50 | urgent appeal for help Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Brom Init not done Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! Card found : S/N : E3B1B8F3 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 148 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454841454538011EAEF1566491 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EEAH [eMMC] : FLASH_CID : 700100454841454538011EAEF1566491 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x9BE78CE1EEEF326C4B60ABB18A995146 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear RDP Clear Error! Done! Elapsed: 00:03:10 Reconnect Power/Cable! It was the same with cm2mt 2.06. Thereafter,l disconnected battery and got this: what shall l do please |
06-18-2019, 09:10 | #3 (permalink) |
Member: 974244 Status: Offline Thanks Meter: 50 | here is the emmc test result Card found : S/N : E3B1B8F3 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454841454538011EAEF1566491 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EEAH [eMMC] : FLASH_CID : 700100454841454538011EAEF1566491 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x9BE78CE1EEEF326C4B60ABB18A995146 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery ) [Processing] FlashMemory Read-Write test [eMMC] : [KINGSTON] , 8EEAH , 0x390000000 , 14592 MiB [eMMC] : CID : 700100454841454538011EAEF1566491 [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:45 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! the above is without battery,but when l connected the battery,l got this: Card found : S/N : E3B1B8F3 , v0137 Chinese Miracle II [MTK module] v 1.58 Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Inital Boot Ok! BB_CPU_PID : 6580 BB_CPU_NME : [MediaTek] MT6580_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x94 NAND Flash : NOT INSTALLED eMMC Flash : 700100454841454538011EAEF1566491 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x70 , OEM : 0100 [eMMC] : FLASH_INF : [KINGSTON] , 8EEAH [eMMC] : FLASH_CID : 700100454841454538011EAEF1566491 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x0000000390000000 [eMMC] : FLASH_UCP : 14592 MiB [eMMC 16 GiB] DEV RID : 0x9BE78CE1EEEF326C4B60ABB18A995146 INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : Unknown ( Not supported (EmbdedBattery) or Without battery ) [Processing] FlashMemory Read-Write test [eMMC] : [KINGSTON] , 8EEAH , 0x390000000 , 14592 MiB [eMMC] : CID : 700100454841454538011EAEF1566491 [eMMC] : MODE : SQ-WR [FAILED] : Probably, something wrong with eMMC! Check cable and battery! Operation Failed Elapsed: 00:00:45 Reconnect Power/Cable! Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 142 ] Sync... Open port error , something went wrong! Boot Error! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! and the phone vibrates and shows charging sign |
