03-21-2019, 11:18 | #1 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Tanzania
Member: 2229290 Status: Offline Thanks Meter: 66 | HUAWEI huawei y541-u02 format failed & write pac file failed Code: Card found: S/N : , v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP SC77xx [Model Select] SLDR Load Ok BB CPU : SC7731 Huawei Y541-U02 (Y5C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Loading : Y541-U02V100R001C567B105.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y541-U02V100R001C567B105 FastCheck : 0x005C906BAD Loading files ... File : fdl1-sign.bin File : fdl2-sign.bin File : nvitem_efuse.bin File : nvitem_wcn.bin File : u-boot-spl-16k-sign.bin File : SC7702_sc7731g_y560_efuse_AsiaPacific-sign.bin File : DSP_DM_G2-sign.bin File : SC8800G_x30g_wcn_dts_modem-sign.bin File : boot-sign.img File : recovery-sign.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : sysinfo.img File : custom_SPC_SEA.img File : prodnv.img File : cache.img File : u-boot-sign.bin File : dlstat.bin File : globalinfo.img File : SC7731_2341A_efuse.xml Load Ok! Operation : Flash [ v1.27 ] ======= Flash Files set for flashing : [ MCU ] : Y541-U02V100R001C567B105.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y541-U02V100R001C567B105 File : fdl1-sign.bin File : fdl2-sign.bin File : nvitem_efuse.bin File : nvitem_wcn.bin File : u-boot-spl-16k-sign.bin File : SC7702_sc7731g_y560_efuse_AsiaPacific-sign.bin File : DSP_DM_G2-sign.bin File : SC8800G_x30g_wcn_dts_modem-sign.bin File : boot-sign.img File : recovery-sign.img File : system.img File : userdata.img File : boot_logo.bmp File : boot_logo.bmp File : sysinfo.img File : custom_SPC_SEA.img File : prodnv.img File : cache.img File : u-boot-sign.bin File : dlstat.bin File : globalinfo.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 77 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Boot failed! Boot failed! Reconnect Power/Cable! Code: Card found: S/N : v0137 Chinese Miracle II [SPD module] v 1.27 Set mode to : SP SC77xx [Model Select] SLDR Load Ok BB CPU : SC7731 Huawei Y541-U02 (Y5C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Format File System / Reset Settings [ v1.27 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys -> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key 3. Insert cable ==== Wait for phone... Phone found! [ 77 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
