12-21-2017, 17:45 | #1 (permalink) |
Freak Poster Join Date: Jan 2011 Location: dhaka
Member: 1482507 Status: Offline Sonork: 158 Thanks Meter: 11 | huawei lua-22 frp lock solution need Phone found! [ 25 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:04 Reconnect Power/Cable! |
12-21-2017, 17:53 | #2 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Quote:
2. Open the folder "SP_Flash_Tool_v5.1532.00" from the previously unpacked archive, and run the attachment "flash_tool.exe" 3. In the "Download Agent" line, insert the file "DA_LUNA_KEY.bin" it is located in the folder "SP_Flash_Tool_v5.1532.00" 4. In the line "Scatter-Loading" we insert the file "MT6582_Android_scatter.txt" it is in the folder "FRP" 5. Press the "Download" button and then connect the switched off phone to the computer. The red line will run, then the yellow one and give a tick, the end of the process. 6. Turn on the phone, adjust the initial settings. 7. We are happy))))) https://cloud.mail.ru/public/4XJr/hAiqjVwbm | |
The Following 2 Users Say Thank You to vasko_bojilov For This Useful Post: |
12-10-2018, 09:17 | #4 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Dar es Salaam TANZANIA
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Card found : 131//////// Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : CACHE Format Ok : USRDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
12-10-2018, 10:47 | #6 (permalink) |
Member: 53263 Status: Offline Sonork: gsm master Thanks Meter: 326 | Card found : 1319A611 , v0137 Infinity-Box Chinese Miracle MediaTek Service Module [ MTK ] v2.02 Load IDBase v11861 Ok! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : CACHE Format Ok : USRDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] Info : Operation break by user! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : BOOTROM MODE : 0_base : BASE_v1712 | Manual : Enabled Fail to disable Dog! AGENT : Look for suitable BootChain in DA ... AGENT : AGENT : Selected AGENT doesn't have required configuration! Check and select CORRECT SETTINGS for your device! Reconnect Power/Cable! DAgent : BAD or DAMAGED file selected! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MTK USB Port (COM60) MODE : BOOTROM PORT : 60 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable/connection/driver! Check SW hint! Repeat operation! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! Operation : Memory Tool Init [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Set default path : C:\InfinityBox\CM2MT2\phdata\ Ready! Close MemoryTool session Done! Elapsed: 00:01:36 Reconnect Power/Cable! Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Miracle PreLoader USB VCOM (Android) (COM46) MODE : PRELOADER PORT PORT : 46 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : 0_base : BASE_v1712 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A019065314738F050070581730AC8 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A483847316550750F0C80A7381 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 4EE5AAB8CEB562F43A6BA9ECF6FC7BD STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
