11-17-2018, 16:13 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: PAKISTAN
Member: 1537135 Status: Offline Thanks Meter: 1,021 | HUAWEI LUA-U22 Error : FRP Failed erase block Operation : Identify [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM24) MODE : PRELOADER PORT PORT : 24 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : LUA-L21, LUA-L22 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A0190653147389A4F070515A35602 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074F9A256A315 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 83135265FC9B0E9E9ACBC3B0EFFBDB6B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! Patch Level : HUAWEILUA-U22 Display ID : LUA-U22C328B005 Ver. CodeName : REL Ver. Release : 5.1 Sec. Patch : 2016-03-01 Build Time : 1462084086 Product Model : HUAWEI LUA-U22 Product Brand : HUAWEI Product Name : LUA-U22 Product Device : HWLUA-U6582 Product Board : LUA-U22 Product Manfct : HUAWEI Board Platform : mt6582 Product Info : HWLUA-U6582 USERDATA : PLAIN ( NOT encrypted ) Done! Elapsed: 00:00:18 Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM24) MODE : PRELOADER PORT PORT : 24 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : LUA-L21, LUA-L22 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : DA_LUNA_KEY.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A0190653147389A4F070515A35602 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074F9A256A315 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 83135265FC9B0E9E9ACBC3B0EFFBDB6B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! PLZ HELP infinity-box team |
The Following User Says Thank You to naveedullah0044 For This Useful Post: |
11-17-2018, 16:53 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | Select FRP RESET PROTECTION if dont work Select full factory(Forced Frp) Results |
The Following User Says Thank You to Kirumira For This Useful Post: |
11-17-2018, 17:11 | #4 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Select FRP RESET PROTECTION Same results any help me Select FRP RESET PROTECTION same results Operation : Reset Settings/Format FS [ v2.02 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM24) MODE : PRELOADER PORT PORT : 24 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 TYPE : LEGACY MTK BROM : SecLevel : 0x00000000 BROM : SecMode : PLAIN [+PRL] BROM : PRELOADER PORT MODE : Huawei : LUA-L21, LUA-L22 | Manual : Enabled AGENT : Look for suitable BootChain in DA ... AGENT : MTK_AllInOne_DA_SP.bin AGENT : Found MT6582 AGENT : MTK_DOWNLOAD_AGENT BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 484A0190653147389A4F070515A35602 DAInf: 4 : 2 : 135 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A48384731655074F9A256A315 EMMC: VEN : HYNIX | OEM : 4A01 | DEV : H8G1e EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6582 , SBID : 0x8A00 , HWVR : 0xCA01 , SWVR : 0x0001 , EVOL : 0x0000 RNID : 83135265FC9B0E9E9ACBC3B0EFFBDB6B STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! ERR : 0x0000177C ERR : SECURITY : SF CODE FORMAT FORBIDDEN ERR : 0x00000000|0x00000000 Error : Failed erase block! Try select another format mode! Reconnect Power/Cable! |
11-18-2018, 08:05 | #7 (permalink) |
Member: 1537135 Status: Offline Thanks Meter: 1,021 | Huawei lua-u22 frp lock done by cm2 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 20 ] Sync... Inital Boot Ok! BB_CPU_PID : 6582 BB_CPU_NME : [MediaTek] MT6582_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x87 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483847316505074F9A0256A315 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x40000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , e1G8 [eMMC] : FLASH_CID : 90014A483847316505074F9A0256A315 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000001D2000000 [eMMC] : FLASH_UCP : 7456 MiB [eMMC 8 GiB] DEV RID : 0xB9E2EB778919B4C4B7DC48603F8410AF INT RAM : 0x00020000 EXT RAM : 0x40000000 [1 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:19 Reconnect Power/Cable! all reply thanks but mostly thanks kamal_singla for help me |
02-27-2019, 17:11 | #8 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: UNLOCKING IN GENERAL:) Age: 51
Member: 196126 Status: Offline Thanks Meter: 80 | Quote:
Its working Thx confirmed | |
