11-04-2015, 20:36 | #1 (permalink) |
No Life Poster Join Date: Feb 2010
Member: 1228709 Status: Offline Thanks Meter: 268 | Huawei MediaPad T1 ? I want to repair IMEI, but, im stuck here because i cant find drivers: Code: USB\VID_12D1&PID_4D01&MI_00 Code: Operation : Check/Read Info [ v1.05 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 176 ] Port Opened Sync... InitSvc Done Wait for phone... Device init not done Check Drivers Try again |
11-05-2015, 11:20 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Got device. Played with it. As expected it secured. In near few days make something for them. |
12-29-2015, 18:42 | #4 (permalink) |
Member: 1228709 Status: Offline Thanks Meter: 268 | Hey, Jaydi, im working again with this tablet but i cant find the driver for that PID/VID Im trying to repair imei. ==== Wait for phone... Phone found! [ 59 ] Port Opened Sync... InitSvc Done Wait for phone... Device init not done Check Drivers Try again And, if i check write in flash mode, i get this: Phone found! [ 59 ] Port Opened Sync... Initial Boot Failed! Elapsed: 00:00:26 |
12-29-2015, 19:38 | #5 (permalink) |
Member: 1228709 Status: Offline Thanks Meter: 268 | Update, now im stuck at this stage: I had check all sldr but none is working, also, i dont found PAC for this tablet. ==== Wait for phone... Phone found! [ 60 ] Port Opened Sync... Normal Mode init Sync... Phone Initial Info : Compile : œ Phone Security Info : IMEI [1] : 000005100C900E6 IMEI [2] : 602075627D69637 BT_ADDR : 007E6E6F6973 Done Write new security data : IMEI1 : 111111111111119 Write Error , 0x007E7E00 Elapsed: 00:00:23 |
12-30-2015, 05:37 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | @JorgeVla, it have blocked SVC sub. Device on every command answer " not permitted " , also it not enter in FlashMode. That is reason why it not present in UpdateLog. So, there is one way - SD upgrade. I have few ideas about how to work with it, but make something for only one device - strange idea. Will try anyway. |
