10-31-2018, 09:50 | #1 (permalink) |
No Life Poster Join Date: Feb 2013 Location: U.P-75 ETAWAH Age: 34
Member: 1889562 Status: Offline Thanks Meter: 617 | pls help mi my cm2 new activation not work cm2 activation my new activation date 31/10/2018 ===Dongal maneger[infinty] v1.72[10/31/2018 14:16:52] === Searching... Dongale can't be found: Card with sopcified AID is not found |
10-31-2018, 10:22 | #2 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | === DongleManager [Infinity] v1.72 [10/31/2018 14:51:42] === Searching... Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00037FF200001942 Box/Dongle is not found |
10-31-2018, 10:23 | #3 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | === DongleManager [Infinity] v1.72 [10/31/2018 14:53:17] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 00037FF200001942 === Process started: 10/31/2018 14:53:19 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
10-31-2018, 11:20 | #4 (permalink) | |
- Run CardID software - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
10-31-2018, 11:27 | #5 (permalink) | |
Member: 1889562 Status: Offline Thanks Meter: 617 | Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: A0000000030000 SerialNumber: 00037FF2 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 0017 Serial Number: 00037FF2 Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 0017 IC Card Manufacturer: 1943 IC Em******* Date: 0017 Pre Personalizer: 1944 Pre Personalization Date: 0017 Pre Personalization Equipment Identifier: 0000C118 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 00037FF200001942 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) Quote:
10-31-2018, 11:29 | #6 (permalink) |
Member: 1889562 Status: Offline Thanks Meter: 617 | Card-Reader: Gemalto e-gate Smart Card 0 ATR: 3B759400006202020201 Card Manager: A0000000030000 SerialNumber: 00037FF2 ROM: Integrated Circuit Fabricator: 4090 Integrated Circuit Type: 0062 OS: Identifier: 0011 Release Date: 0202 Release Level: 0100 EEPROM: Fabrication Date: 0017 Serial Number: 00037FF2 Batch Identifier: 0000 Module Fabricator: 1942 Module Packaging Date: 0017 IC Card Manufacturer: 1943 IC Em******* Date: 0017 Pre Personalizer: 1944 Pre Personalization Date: 0017 Pre Personalization Equipment Identifier: 0000C118 Personalizer: FFFF Personalization Date: FFFF Personalization Equipment Identifier: FFFFFFFF m_iopCard.Serial: 00037FF200001942 Extended info: Card returned error message . ISO7816 error 0x6A86 (Wrong parameter(s) P1-P2. Incorrect parameters P1-P2 ) |
10-31-2018, 11:31 | #7 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | - Run DongleManager - Update Dongle firmware now IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! |
