Old 03-28-2017, 14:25   #1 (permalink)
pradip980492750's Avatar
Member: 1344199
Thanks Meter: 13
please help htc 626 cant flas with cm2
info
Brand : htc
ProdName : htc_asia_sea_wwe
ProdModel : HTC Desire 616 dual sim
Device : htc_v3_dug
AndroidVer: 4.2.2
MTKxCPU : MT6592
MTKxPRJ : SW_G98518A2_V019_M10_HTC_V3DUG_ASIA_MP
flash procedure
Operation : Flash [ v1.58 ]
======= Flash
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6592
BB_CPU_NME : [MediaTek] MT6592_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x8A
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A478B8A1E7
Initialize Memory ...
DAgent sent , init HW now
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A478B8A1E7
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : 0xCCFB2663BA0CB146407182CF6E7C6BB4
INT RAM : 0x00020000
EXT RAM : 0x40000000 [1 GiB]
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6592 , Project : wt98518 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 3849 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000000000-0x0000000000100000
Erase : 0x0000000001D00000-0x00000000E3E00000
Flash Pre-Erase Done, time used : 00:00:00
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98518.bin
Preloader Sent , Init passed
PartCount : FFFFFFFF
PartErr : Not initialized , will update PMT now ...
Repartition Failed! Something wrong with HW or BL? Try make "Flash Erase" first!
Operation Failed
Elapsed: 00:00:17
Reconnect Power/Cable!
Page generated in 0.12703 seconds with 9 queries
