HUAWEI T1-701U Sp Unlock cant Connect HUAWEI T1-701U SPD cant connect so that I can I unlock [CODEChinese Miracle II [SPD module] v 1.13 Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 88 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable!][/CODE] Tryed more than 3 phones :confused: Need ur help thanx |
And will not connect. Check a little over search. All already explained. |
Sure, can check all , what you need to know about this model here |
Not Supported Quote:
==================================== 10:18:03 - Starting ADB Server.. 10:18:09 - Manufacturer: HUAWEI 10:18:09 - Model: T1-701u 10:18:09 - Android Version: 4.4.2 10:18:09 - Build ID: T1-701uV100R001C199B005 10:18:09 - Board ID: sp7731gea_lm 10:18:09 - Chipset Platform: sc8830 10:18:09 - Checking Root access: True ====================================== Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 51 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_HUAWEI_PAD_W15.17_P1_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 04-21-2015 16:27:53 Phone Security Info : IMEI [1] : 86693602xxxxxxxx (Huawei MedaiPad T1-701u have one imei) IMEI [2] : 352751019523267 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.869 V Done Can only read info in service mode other functions no Salam Salam |
so, can this model be unlocked or not ? |
unlock is not possible :mad: |
