01-30-2016, 14:43 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | HUAWEI T1-701U Sp Unlock cant Connect Operation : Check/Read Info [ v1.13 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 88 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable!][/CODE] Tryed more than 3 phones Need ur help thanx |
01-30-2016, 16:20 | #5 (permalink) | |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Quote:
01-31-2016, 05:25 | #7 (permalink) |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Not Supported I think i have gathered All info I need: http://forum.gsmhosting.com/vbb/f296..._701u-2041977/ You can CLOSE This thread |
02-11-2017, 12:10 | #8 (permalink) |
No Life Poster Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Offline Thanks Meter: 162 | ==================================== 10:18:03 - Starting ADB Server.. 10:18:09 - Manufacturer: HUAWEI 10:18:09 - Model: T1-701u 10:18:09 - Android Version: 4.4.2 10:18:09 - Build ID: T1-701uV100R001C199B005 10:18:09 - Board ID: sp7731gea_lm 10:18:09 - Chipset Platform: sc8830 10:18:09 - Checking Root access: True ====================================== Operation : Check/Read Info [ v1.24 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 51 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_HUAWEI_PAD_W15.17_P1_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 04-21-2015 16:27:53 Phone Security Info : IMEI [1] : 86693602xxxxxxxx (Huawei MedaiPad T1-701u have one imei) IMEI [2] : 352751019523267 BT_ADDR : 000000000000 SelfInfo : BatVoltage : 3.869 V Done Can only read info in service mode other functions no Salam Salam |
The Following User Says Thank You to abdoune For This Useful Post: |
04-19-2017, 19:41 | #10 (permalink) | |
No Life Poster Join Date: Feb 2006 Location: Club-Berry
Member: 238127 Status: Offline Sonork: 100.1574867 Thanks Meter: 3,526 | Quote:
The Following User Says Thank You to y3kt For This Useful Post: |
