Old 12-11-2018, 02:23   #1 (permalink)
Member: 85718
Thanks Meter: 448
Huawei T1-701W
Is possible manage this Tablet with Processor SC7731G with SPD module?
I have tryed using WINXP and WIN7 but cant read / identify. Drivers are instaled , COM Port detected. Have tryed EDL cable , both vol buttons, separate vol buttons but no success.
Someone have some experience with this equipment ?
The equipment is full working , anyway i am trying to create a firmware backup.
The Following User Says Thank You to ct3im For This Useful Post:
Old 12-11-2018, 05:36   #2 (permalink)
bhalaygilani's Avatar
Member: 1647864
Thanks Meter: 80
Can you share log here?
Or spd module is not detecting this tablet?
Old 12-11-2018, 16:30   #3 (permalink)
Member: 85718
Thanks Meter: 448
Chinese Miracle II [SPD module] v 1.27
Set mode to : SP [SC773x] eMMC [Generic 4.x-5.0]
Operation : Check/Read Info [ v1.27 ]
1. Remove battery. Insert battery back
2. Press and hold 'VolumeUp' and 'VolumeDown' keys
-> Alternative : just ONE 'VolumeUp' or 'VolumeDown' key
3. Insert cable
==== Wait for phone...
Phone found! [ 68 ]
Port Opened
Sync...
Initial Boot Failed!
Boot not done, reason : Wrong BootKeys
Hint : Reset power and use ANOTHER BootKey ( VOL up or VOL down )
Reconnect Power/Cable!
Have tryed diferent key sequences but no success.
Old 12-11-2018, 17:16   #4 (permalink)
Member: 1647864
Thanks Meter: 80
3. Insert cable
Phone found! [ 68 ]
Port Opened
Sync...
As per log info it is clear that correct boot key is not pressed so
You must Try boot jig if u have ...but if u don't have
And also have no knowledge about it, you can message me, I'll guid you. It is very simple
Old 12-11-2018, 21:35   #5 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 20,352
Huawe had closed protocl on tablets on all levels.
It will not work with SPD module.
The Following User Says Thank You to JayDi For This Useful Post:
Old 12-13-2018, 01:28   #6 (permalink)
Member: 85718
Thanks Meter: 448
Thank you for your cooperation, atm is not necessary because Tablet is full working , anyway i have interesse in creating a backup If in future i have problems i could flash with backup.
Thank you.
Page generated in 0.17165 seconds with 8 queries
