07-08-2010, 08:49 | #1 (permalink) |
Freak Poster Join Date: Jan 2006
Member: 226190 Status: Offline Thanks Meter: 22 | Huawei t128 test power on Can any one give any solution? Here is log below. COM3 [VCP0] selected module v1.78 Device: Huawei-T128-HW-A Checking data, wait... Action: "sp-unlock" 1. Make "read flash" operation 2. Make "read eeprom" operation, so you will have backup for emergency case ATTENTION: save this backup file in safe place and note IMEI for each eeprom backup file ! 3. Make "unlock" operation 4. Phone should be unlocked, but imei will be changed 5. Before unlock check that you have an ability to repair imei Test phone with new imei, is it will be valid for all your networks. In case of any problems you can write back eeprom backup and original imei will be back. Do you want to continue ? direct unlock Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... sw version: 007 T128MZ 11 21 31 O Check parameters Done backup critical area ... reading eeprom-static... file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-static_20100703-171906.B1E.bin loading data... wrong database file: x:\Program Files\InfinityBox\Pana01\T128_eep65535.cfg error: can't load database v.1106 reading eeprom-security... file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-security_20100703-171908.B1E.bin reading eeprom-complete... file saved: x:\Program Files\InfinityBox\Pana01\Huawei-T128-HW-A_eeprom-complete_20100703-171923.B1E.bin backup critical area Done Check memory ... Check memory Done Write ... Erasing: eeprom-complete Writing: eeprom-complete Write Done Finished, time used: 56 sec Remove/Install battery now ! COM3 [VCP0] selected module v1.78 Device: Huawei-T128-HW-A Checking data, wait... Action: "repair imei" new imei: 357563012818478 Boot ... Press and HOLD Power button now ! e-gold: A0 loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... loading data... error: source buffer too small: 00000000 instead of 0000000A reading eeprom-security... reading eeprom-complete... reading additional data... error: can't read imei-area warning: can't read lock-area backup critical area Failed Finished, time used: 2 min 13 sec Remove/Install battery now ! Finished |
The Following User Says Thank You to vaskar For This Useful Post: |
6110 power does not stay on | sc~micro | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 08-30-2014 08:14 |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
