11-04-2009, 06:27 | #1 (permalink) |
Freak Poster Join Date: Jan 2009
Member: 950629 Status: Offline Thanks Meter: 105 | ALFATEL H2 wrong packet cs Error on Infinity When i going to make format, infinity show me an errors. How I Slove this Prob??? This is the log COM4 [VCP1] selected module v2.91 Action: reset settings Model: Autodetect 6205-6227 NOR Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! 19200 autodetect Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:000A status: FF Connecting at 19200, wait... Release Power button now ! Phone detected, wait... warning: can't read software version, probably unknown firmware detecting structure #2... 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18warning: wrong packet cs 19 20 21 22 23 24 25 26 27warning: wrong packet cs 28 29error: detection failed (30 tries), read flash and send to support connection lost error: operation failed ! Finished, time used: 15 sec Remove/Install battery now ! Info of phone COM4 [VCP1] selected module v2.91 Device: Autodetect 6205-6227 NOR Checking data, wait... advanced flash detection enabled Action: read/check detailed information Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 high speed boot On chip: 0001:9703:000A status: FF boot packet size: 0400 Release Power button now ! Boot Done Initialize ... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #02 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #03 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb number of flash chip/regions detected: 04/01 Initialize Done Set baud ... 115200 Set baud Done Initialize bootcode ... Initialize bootcode Done Check firmware integrity ... device parameters autodetection in progress... detecting chip #00 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb detecting chip #01 in region #00... flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed flash: AMD/Fujitsu std [def 0008x002000 00FFx010000] 16Mb it's time to stop: 18F09FE518F09FE518F09FE518F09FE518F09FE518F09FE5 number of flash chip/regions detected: 01/01 total flash region size: 01000000 detect device rom info... detection phase #1... detect device rom info finished rom info structure: 2nd [enhanced] generation startup code area #1 is Ok startup code area #1 backup saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\id.B6777180.[HUSCKY7_S62_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN_99FDBEF6].rpl ==================== New firmware detected (v.2.91, database date: unknown): HUSCKY7_S62_18V_PCB01_GPRS_MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN This firmware is missing in support area. If this phone is good and working: - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to http://rapidshare.com or http://4shared.com - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info detection finished device-id: B6777180 rom info protocol ver: 04 ver. sw 1: HUSCKY7_S62_18V_PCB01_GPRS_ MT6225_S00.PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O.BIN ver. sw 2: PN-SC_CN_LLNUMLD_242_YYMMDD_CAM_MCPMCP_O, 09410266 ffs offset/size: 00E00000/00200000 detecting ffs/eeprom area in 1 chip(s)... standard ffs/eeprom offset detected: 00E00000 flash: EC240200000000:18E59F00000000 error: detected/calculated [01000000/00010000] chip size mismatch, chip detection failed checking area [00000000]: 00000000-00FFFFFF... ffs/eeprom found near: 00E00000 detecting ffs/eeprom size... ffs/eeprom size: 00200000 ffs/eeprom chip: 00 ffs/eeprom area: 00000000:00E00000-00FFFFFF detecting ffs/eeprom structure pass 1... .......................... detect standard fat location pass #1... ...................................................... detect standard fat offset pass #1... detect standard fat data... fat layout detection complete ffs/eeprom detected ok: element #1 file saved: C:\Program Files\InfinityBox\ChineseMiracle\backup_security\_system_log_B6777180_99FDBEF6_20091103-180402.B0X.bin Finished, time used: 46 sec Remove/Install battery now ! |
11-08-2009, 10:44 | #3 (permalink) | |
I was a problem with new type of phone hardware. Please, try to use this software for flashing: http://www.infinity-box.com/download...acle_v2.97.rar It was tested with new flash chip types. Waiting for your results. | |
wrong packet cs | moyalaslam | Infinity-Box | 5 | 11-13-2009 20:12 |
Warning: Wrong packet cs | drjaved_akhter | Infinity-Box | 1 | 09-26-2009 14:14 |
wrong packet cs when trying to format ffs | chikubie | Infinity-Box | 3 | 06-20-2008 20:38 |
wrong packet cs need help????? | leomuns | Infinity-Box | 1 | 06-13-2008 15:44 |
