Old 03-21-2010, 06:11   #1 (permalink)
Member: 982335
Thanks Meter: 202
How to write imei of lg b2060? Big problem!
HOW TO WRITE IMEI OF LG B2060?
I HAVE FULL FLASH THE SET.
WRITE GOOD EEPROM FILE.
ALSO WRITE IMEI IN SERVICE MENU BUT STILL THE IMEI IS 0000?
NEED HELP FROM INFINITY TEAM.
COM6 [VCP0] selected
module v1.39
Device: LG-B2060
Checking data, wait...
Action: imei repair
Boot ...
Connecting, wait...
Release Power button now !
flash: 01227E22212200:FEEA0000000000
flash: Amd AMD/Fujitsu std [D 0004x010000 003Ex040000 0004x010000] 16Mb
Boot Done
Set baud ...
115200
Set baud Done
Check flash ...
current eeprom imei: 3533730100*****
current otp imei: 3533730100*****
file saved: C:\Program Files\InfinityBox\LGA\eeprom_353373010001307_LG-B2060_20100321-102640.B1E.bin
version: XXX-XXV10l91B2060P40
Check flash Done
Check space ...
Check space Done
Check parameters ...
Check parameters Done
Erase ...
Erase Done
Write ...
Write Done
Finished, time used: 31 sec
Remove/Install battery now !
Old 03-22-2010, 04:21   #2 (permalink)
Member: 982335
Thanks Meter: 202
why nobody helping me out in this matter?
is it not possible to write imei of lg b2060 with infinity?
should i need other tool (et) for this job?
Old 03-22-2010, 06:09   #3 (permalink)
ranagaurav's Avatar
Member: 907098
Sonork: 100.1601140
Thanks Meter: 705
u give therd ? infinity
Old 03-22-2010, 07:04   #4 (permalink)
Member: 982335
Thanks Meter: 202
i just wanted to know is it possible do that job with infinity?
INFINITY BOX IS GREAT.
SO THE EXPECTATION IS HIGH.
Old 03-22-2010, 12:04   #5 (permalink)
Member: 533010
Thanks Meter: 16
Lg b2060 imei solution
Bro,
Flase This Attached flash file. Set will be ok. I Tested Many Handsets.
"KG110P40FL-91-V10d_404-XX_OCT-16-2006_full_code_alchemy_352691010123453[1].B1M.bin"
The Following 2 Users Say Thank You to rajkamal_kasdol For This Useful Post:
Old 03-22-2010, 15:32   #6 (permalink)
Member: 982335
Thanks Meter: 202
Originally Posted by rajkamal_kasdol View Post
Bro,
thanks sir.
problem solved.
The Following User Says Thank You to Rin2 For This Useful Post:
can anyone tell me how to write IMEI to china mobile? palav Chinese Models & Cloned Phones 2 12-09-2009 14:08
How to write IMEI-0000000000 in lg-kp105 kabiyal VygisToolbox 0 10-25-2009 07:34
How to Repair IMEI of LG CU400 bornagaintobe FuriousGold 2 10-15-2009 22:27
How to repair imei of LG u990 mobile_master20 FuriousGold 3 06-02-2009 10:40
how i write imei of samsung T219s sukhdeep Samsung Hardware Repair 0 06-25-2008 06:46
Page generated in 0.21621 seconds with 9 queries
