12-22-2008, 14:45 | #1 (permalink) |
Freak Poster Join Date: May 2006 Location: SUDAN Age: 39
Member: 271980 Status: Offline Sonork: 100.1573370 Thanks Meter: 227 | Huawei T156 unlock Successfully module v1.58 Device: Huawei-T158 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 921600 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-static_20081222-053923.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-security_20081222-053924.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_eeprom-complete_20081222-053925.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T158_lock-area_20081222-053927.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 20 sec Remove/Install battery now ! |
The Following 5 Users Say Thank You to kabo tel For This Useful Post: |
12-22-2008, 15:08 | #3 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | Pls can u share the cable pinout ? I have a self-made setool box cable which works well for j132, but surprisingly it doesnt work for this T156 !!! I was thinking they are the same pinout. Pls share the pinout or cable name (no matter the interface or box) Thanks |
01-16-2009, 21:00 | #5 (permalink) | |
No Life Poster Join Date: Feb 2005 Location: HOME OF PEACE
Member: 113732 Status: Offline Thanks Meter: 90 | Quote:
My problem is i have over 100 pcs which the owner does not want me to open as they are brand new. help needed. | |
01-17-2009, 18:47 | #7 (permalink) | |
Here is an instruction how to get cable/pinout information: 1. be sure that you have downloaded and installed latest Infinity-Box Pinouts update 2. run Infinity-Box Shell 3. select required model 4. see detailed information about cable/pinout (Rx/Tx/Gnd pins and other information) Here is an example of information given by Infinity-Box Shell: Here is information how to build your own cable: http:///vbb/showthread.php?t=342807 | |
01-20-2009, 03:35 | #8 (permalink) |
Insane Poster Join Date: Nov 2005
Member: 196010 Status: Offline Thanks Meter: 4 | Hello Infinity Team !!! I use Infintiy Pinfinder to detect RX TX and this 's log software version: 1.17 cable type: 1x5 (L5A) platform: CPU independent (autodetect) algorithm searching adapter at COM11... adapter found, version: 2000 pins: 5, plain power cycles: 1 activation cycles: 5 power-off delay: 20 start Rx/Tx: 1/1 Loading configuration... Initializing... Phone should be Powered-On ! Power-On phone now and press "Ok" Be sure that phone is not in sleep mode during pinout detection ! Press any phone key from time to time to wake-up phone. detecting pins... detected baudrate: 115200 result: Rx:3 Tx:4 time required: 15 sec But Infinity Soft can't unlock it ..This 's log : COM11 [VCP0] selected module v1.60 Device: Huawei-T156 Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! error: wrong boot answer #1: Release Power button now Boot Failed Finished, time used: 19 sec Remove/Install battery now ! That's not cable because i test 3 good cables. I check it many many times but always fail..Pls help me Infinity Team !!! You're always the best in GSM. BR. |
The Following User Says Thank You to baongocmobile For This Useful Post: |
01-20-2009, 06:12 | #9 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | i did unlock many times with out any problem , check connection , battery full , connector cleans etc and try with cool mind !! Br Faisal_Computer |
01-21-2009, 03:20 | #11 (permalink) |
Member: 196010 Status: Offline Thanks Meter: 4 | Thanks for your answer Infinity Team !!! But i always used power wires..Anyway in my country it can't unlock by anyone !!! I know many my friends in my country have infinitybox but they can't unlock Huewai T156.Maybe Huewai have some new modify in Huewai Board T156 in my country ? Thanks so much for your help !!! You're always the best team in GSM World !!! BR. |
01-21-2009, 19:31 | #12 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | Hello, Try to select other models from Pana01 module and try to read flash, f.e. try to connect T156 like T128 or T158. Let's see results. |
Huawei T156 Unlock | abidfarooq | Infinity-Box | 41 | 11-20-2016 11:52 |
huawei t156 unlock problem | burraq | Infinity-Box | 48 | 11-05-2011 11:30 |
Huawei T156 Unlocked Successfull(U-fone) | Kanwalgee | SAGEM JTAG UNLOCKER | 14 | 01-25-2010 19:32 |
Huawei T156 unlock problem with me | Tahir Riaz | Infinity-Box | 8 | 12-22-2008 11:00 |
huawei t156 unlock | mohd aji | Infinity-Box | 6 | 11-21-2008 14:20 |
