Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2006 Location: WITH SOME SELFISH PEOPLE
Member: 294880 Status: Offline Sonork: 100.1587133 Thanks: 78
| Huawei-T161L unlock successull COM14 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090128-122611.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090128-122612.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090128-122619.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090128-122638.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 154 sec Remove/Install battery now ! |
| The Following User Says Thank You to saqibmalik For This Useful Post: |
| | #2 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2005 Location: infinity-box
Member: 130995 Status: Offline Thanks: 9,039
| Thank you very much for test report ! Each test report with attached logs is very important for us so we can see how is Infinity-Box software works and what is possible problems (so we will be able to fix it) and successfully done work. |
| | #4 (permalink) |
| Junior Member Join Date: Apr 2008 Location: Pakistan
Member: 761465 Status: Offline Thanks: 3
| unlock successull COM14 [VCP0] selected module v1.60 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090128-122611.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090128-122612.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090128-122619.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090128-122638.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 154 sec Remove/Install battery now ! but call not make |
| | #6 (permalink) |
| Download:InfinitySupport site:Huawei model.T161L (1)Write firmware and eeprom:Huawei model.T161L (2)Sp-Unlock : unlock method-1 Mobile on display before Jazz display show. Mobile on display after new display show (TELMA). but cal not make any network i have back up full flash file i send u this file pls uplode firmware file |
| | #10 (permalink) |
| Hello, Huawei-T161L_R03.T02.00_R_T161L_01_A_T161L_09_main_lp_Jaz z file uploaded in "main" support area. |
| The Following User Says Thank You to InfinitySupport For This Useful Post: |
| | #11 (permalink) | |
| Quote:
i download Huawei-T161L_R03.T02.00_R_T161L_01_A_T161L_09_main_lp_Jaz z file from infinity support site But this file give error see log Loading data, wait... S/N: 000?????? Wait... Device: Huawei-T161L Ready Loading file v.02... error: data error ! Loading failed, probably damaged data file | |
| | #12 (permalink) | |
| Quote:
Bi sorry, it was my faulyt. Please, download file from "main" support again now. | |
| | #13 (permalink) | |
| Quote:
i download jazz file and eeprom eeprom give errer bad data file i update sowtware but my problem not solive cll not make singnel after same time walkup my idea this problem in rpl pls give me addivice ty | |
| | #14 (permalink) |
| Hello, Eeprom #2 was re-uploaded, please try to download it again. If it will be the same problem with network after eeprom file I think you must check phone hardware due to it may be this your phone has 850/1900 hardware. Waiting for your results. |
| | #15 (permalink) | |
| Quote:
i chack my phone in hardware ok 900/1800 but my phone same problem show network singnel i make call mobilink network 123 show message call disconnected may be problem in rpl or eeprom after unlocking my phone in working on jazz network finely plssssssssssssssssssssssssssss hellp me | |
| The Following User Says Thank You to ATmaga8L For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Huawei c-5100 unlocking solution | mobile.doctor | Various CDMA/TDMA Cell Phones | 3 | 03-29-2010 14:06 |
| WORLD FIRST IN INDIA UNLOCK Huawei U1280 Huawei U7510s Huawei U7519 iNQ Chat 3G ETC | chiragsp_codes | Main Sales Section | 0 | 02-13-2010 07:28 |
| 25 Nov 2008: ZTE/Voda/Huawei unlock improved (SIM LOCKED), imei, SFR-341, Huawei-T161 | InfinitySupport | Infinity-Box | 73 | 02-01-2009 05:46 |
