Old 05-07-2009, 05:59   #1 (permalink)
Member: 677796
Thanks Meter: 102
Huawei-T161L SIM INVALID 100% OK
Huawei-T161L SIM INVALID . . . . .
write eperom file. . .
change IMEI 100% ok ..
COM17 selected
module v1.60
Device: Huawei-T161L
Checking data, wait...
Action: "repair imei"
new imei: 353960024487140
Boot ...
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20000624-195051.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20000624-195052.B1E.bin
reading eeprom-complete...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20000624-195058.B1E.bin
reading additional data...
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_imei-area_20000624-195118.B1E.bin
file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20000624-195139.B1E.bin
backup critical area Done
Check memory ...
lock found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Erasing: eeprom-security
Writing: eeprom-security
Write Done
Finished, time used: 116 sec
Remove/Install battery now !
Finished.......................
The Following User Says Thank You to kashi4lucky For This Useful Post:
Old 05-09-2009, 18:44   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,407
COM17 selected
module v1.60
Boot ...
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
115200
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
imei found #1
Check memory Done
Write ...
Erasing: imei-area
Writing: imei-area
Erasing: lock-area
Writing: lock-area
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
The Following User Says Thank You to InfinitySupport For This Useful Post:
Huawei-T161L unlock ok shahid41 Infinity-Box 0 11-18-2009 04:10
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW hassanjinja1 Main Sales Section 0 10-22-2009 13:45
6300 NEW dual sim INVALID sim ok 100% working themobileshop Infinity-Box 1 09-09-2009 18:30
C225 Isert Sim Slution 100% ok gilani4_all Samsung Hardware Repair 3 10-12-2008 10:47
cect T689 opening sim B 100% OK. shoeb7 Infinity-Box 5 09-08-2008 18:48
Page generated in 0.27270 seconds with 8 queries
