Old 03-05-2009, 13:52   #1 (permalink)
zeerik's Avatar
Member: 282066
Sonork: 100.1590696
Thanks Meter: 549
Huawei-T161L successfull unlocked
here is testreport.................thanks goes to infinity team
COM4 [VCP0] selected
module v1.63
Device: Huawei-T161L
Checking data, wait...
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Release Power button now
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
Check parameters ...
Check parameters Done
backup critical area ...
reading eeprom-static...
file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090305-044117.B1E.bin
loading data...
data loaded
reading eeprom-security...
file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090305-044118.B1E.bin
reading eeprom-complete...
file saved: E:\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090305-044119.B1E.bin
reading additional data...
file saved: E:\InfinityBox\Pana01\Huawei-T161L_lock-area_20090305-044123.B1E.bin
backup critical area Done
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Finished, time used: 25 sec
Remove/Install battery now !
The Following User Says Thank You to zeerik For This Useful Post:
Old 03-05-2009, 14:08   #2 (permalink)
InfinityN's Avatar
Member: 720034
Thanks Meter: 209
module v1.63
Action: unlock
unlock method-1
Boot ...
loader: standard
type: 4
loading...
next part...
boot answer: 01
Boot Done
Set Baud ...
921600
Set Baud Done
Connecting ...
flash: 0001:22C4
Connecting Done
Check hardware ...
Check hardware Done
loading data...
data loaded
Check memory ...
lock found
Check memory Done
Write ...
Erasing: lock-area
Writing: lock-area
Write Done
Thank you very much for test report !
Each test report with attached logs is very important for us
so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type)
and what is possible problems (so we will be able to fix it) and successfully done work.
UNLOCK ALL MODEL Huawei T158B,Huawei T156B,Huawei T161L,Huawei,KENYANS CONTACT ME NOW hassanjinja1 Main Sales Section 0 10-22-2009 14:45
Huawei T161L Successfully unlocked zeerik Infinity-Box 2 02-03-2009 18:35
successfull unlock T161L Hafiz ArslanAli Infinity-Box 1 01-20-2009 21:25
Huawei-T161L unlock suss tanha Infinity-Box 1 01-06-2009 19:02
huawei t161L succesfully unlocked gsmbac Infinity-Box 2 11-24-2008 16:48
Page generated in 0.25606 seconds with 8 queries
