02-09-2009, 10:06 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: .:Islam:.:Peace:.Pakistan:. Age: 48
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | Huawei t161L unlock Success module v1.62 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090209-135832.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090209-135833.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090209-135839.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090209-135858.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 34 sec Remove/Install battery now ! |
The Following User Says Thank You to Imran Bhatti For This Useful Post: |
02-09-2009, 11:04 | #3 (permalink) |
Member: 266874 Status: Offline Sonork: 100.1581444 Thanks Meter: 97 | The Second one... COM5 [VCP0] selected module v1.62 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 115200 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090209-150243.B1E.bin loading data... data loaded reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090209-150245.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090209-150251.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090209-150311.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 67 sec Remove/Install battery now ! |
02-09-2009, 17:20 | #4 (permalink) | |
No Life Poster Join Date: Jun 2005 Location: Kamalia, Pakistan. Age: 38
Member: 151871 Status: Offline Thanks Meter: 71,421 | Quote:
i have unlocked over then 450 Mobiles with infinity and on 24Sec Br Faisal_Computer | |
02-10-2009, 22:27 | #6 (permalink) |
Member: 130995 Status: Offline Thanks Meter: 35,227 | How to write flash (upgrade/downgrade firmware, change language): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Flash" page and load required files 8. press "Write" button and follow instruction given by software How to read flash: 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "Read flash" (or "Read full flash") button and follow instruction given by software How to unlock (remove sp-lock, provider lock etc.): 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. press "SP-Unlock" button and follow instruction given by software How to reset/format ffs (reset setting to default values, repair freez/restart etc.): - at first try to make "safe format" (if this option exist) - if "safe" option is not works try to make "complete" format (if this option exist) 1. connect cable from box to device 2. run "Infinity-Box Shell" software 3. select required model 4. run required software module 5. select required model (if need) 6. go to software "Settings" page and select COM port 7. go to software "Service" page 8. select format mode "safe" or "complete" (if mode is available) 9. press "Reset" or "Format" button and follow instruction given by software |
Huawei t161l unlock success | smarter | Infinity-Box | 1 | 05-09-2009 19:45 |
Huawei T161L unlocked successfuly (Jazz Mobilink) | GSM-DOCTOR | Infinity-Box | 9 | 01-21-2009 19:51 |
huawei T161L unlock down all network by infinity box | aleem26 | Infinity-Box | 1 | 01-19-2009 15:11 |
Huawei T161L unlocked :D | kasrawiz | Infinity-Box | 2 | 01-16-2009 00:06 |
Huawei-T161L unlock suss | tanha | Infinity-Box | 1 | 01-06-2009 19:02 |
