huawei t201 error i want to unlock this huawei t201 and got error here is log : COM3 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 5 sec |
yes me too...........................please help |
hey good news Quote:
Can ypu direct me to the link sir? |
Huawei t201 error Quote:
Good information for huawei Quote:
Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now ! loading... boot answer: 01 Release Power button now Boot Done Set Baud... 921600 Set Baud Done Connecting... flash: 0001:011A Connecting Done Check hardware... flash chip supported Check hardware Done Check parameters... Check parameters Done backup critical area... reading [eeprom-sta]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sta_20080930-182321.B1E.bin loading data... data loaded reading [eeprom-sec]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-sec_20080930-182327.B1E.bin reading [eeprom-complete]... file saved: C:\Program Files\InfinityBox\Pana01\backup_eeprom-complete_20080930-182329.B1E.bin reading additional data... done backup critical area Done Check memory... current status: 0 Check memory Done Write... Erasing: lock-area Writing: lock-area Write Done Finished, Remove/Install battery now ! Time used: 26 sec Unlock instruction: 1. Power-On phone 2. Enter code: 12345678 be happy....... |
InfinityUpdate_Pana01_v1.41 Quote:
Me too I have the same problem: COM31 [VCP0] selected Device: Huawei-T201 Checking data, wait... Action: unlock unlock method-1 Boot... Press and HOLD Power button now (if boot does not start remove/install batery) ! loading... next part... error: can't run main loader: Finished, Remove/Install battery now ! Time used: 7 sec |
Hello, Try to use other cable, f.e. ordinary COM port cable. It was some reports from users that this may helps. |
