-   Infinity-Box (http://forum.gsmhosting.com/vbb/f296/)
-   -   Huawei T201:error: can't run main loader: (http://forum.gsmhosting.com/vbb/f296/huawei-t201-error-cant-run-main-loader-613521/)
beneto 10-18-2008 23:14
I have a big problem with huawei t201.Look COM31 [VCP0] selected
Device: Huawei-T201
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
Finished, Remove/Install battery now !
Time used: 7 sec
InfinitySupport 10-18-2008 23:49
Hello,
Try to use other cable, f.e. ordinary COM port cable. It was some reports from users that this may helps.
Jayrus 10-20-2008 00:13
No cable is ok use Pana01_v1.42 everything will be fine. Higher versions of this version have bugs when working on these models so infinity team should solve this error.
alfin5557 10-21-2008 15:00
yes I'm too same problem
beneto 10-25-2008 18:52
No the cable is ok.I need this version:"Pana01_v1.42" Mr.Jayrus ! would you send or write it here,please ?? Here there are so many Huawei T201 that circulate in the region..
.:iTRi:. 10-25-2008 20:13
u can dowload it from archive
root/ software / updates / archive /
abellcell 10-26-2008 05:24
Dear ALL
I have same problem to unlock huawei T201 bundling XL Indonesia
Main loader error
Rgds,
InfinitySupport 10-26-2008 14:31
Hello,
Try to select model ZTE-A36 and unlock phone.
Waiting for your results.
Do not forget to make fulkl flash backup before operation !
SHIHAB 02-21-2009 20:05
Originally Posted by InfinitySupport (Post 3781651)
Hello,
yes work fine with ZTE-A36 100% OK
sharif_sir 02-10-2010 14:08
error: can't run preloader: sir help me how to solve this huaiew T201 network lock code problem
YellowBoss 02-10-2010 17:31
post here operation log text
alok_chp 03-03-2010 19:17
yes bro u r right prob solved thanks for best regards:)
suqami 03-03-2010 21:52
Check the version or cable
Page generated in 0.24472 seconds with 5 queries
