Old 10-18-2008, 23:14   #1 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
Thumbs up Huawei T201:error: can't run main loader:
I have a big problem with huawei t201.Look COM31 [VCP0] selected
Device: Huawei-T201
Checking data, wait...
Action: unlock
unlock method-1
Boot...
Press and HOLD Power button now (if boot does not start remove/install batery) !
loading...
next part...
Finished, Remove/Install battery now !
Time used: 7 sec
Old 10-18-2008, 23:49   #2 (permalink)
InfinitySupport's Avatar
Member: 130995
Thanks Meter: 34,296
Hello,
Try to use other cable, f.e. ordinary COM port cable. It was some reports from users that this may helps.
Old 10-20-2008, 00:13   #3 (permalink)
Jayrus's Avatar
Member: 279790
Sonork: icq: 648661016
Thanks Meter: 25
No cable is ok use Pana01_v1.42 everything will be fine. Higher versions of this version have bugs when working on these models so infinity team should solve this error.
The Following User Says Thank You to Jayrus For This Useful Post:
Old 10-21-2008, 15:00   #4 (permalink)
alfin5557's Avatar
Member: 176999
Thanks Meter: 32
yes I'm too same problem
Old 10-25-2008, 18:52   #5 (permalink)
beneto's Avatar
Member: 148833
Thanks Meter: 25
No the cable is ok.I need this version:"Pana01_v1.42" Mr.Jayrus ! would you send or write it here,please ?? Here there are so many Huawei T201 that circulate in the region..
Old 10-25-2008, 20:13   #6 (permalink)
.:iTRi:.'s Avatar
Member: 240068
Thanks Meter: 199
u can dowload it from archive
root/ software / updates / archive /
Old 10-26-2008, 05:24   #7 (permalink)
Registered User
Member: 461468
Thanks Meter: 139
Dear ALL
I have same problem to unlock huawei T201 bundling XL Indonesia
Main loader error
Rgds,
Old 10-26-2008, 14:31   #8 (permalink)
Member: 130995
Hello,
Try to select model ZTE-A36 and unlock phone.
Waiting for your results.
Do not forget to make fulkl flash backup before operation !
Old 02-21-2009, 20:05   #9 (permalink)
SHIHAB's Avatar
Member: 77862
Thanks Meter: 14
Originally Posted by InfinitySupport View Post
Hello,
yes work fine with ZTE-A36 100% OK
Old 02-10-2010, 14:08   #10 (permalink)
Member: 957309
Sonork: sharifuddin_s
Thanks Meter: 17
error: can't run preloader: sir help me how to solve this huaiew T201 network lock code problem
Old 02-10-2010, 17:31   #11 (permalink)
Member: 1043909
Thanks Meter: 51,293
post here operation log text
Old 03-03-2010, 19:17   #12 (permalink)
Member: 321173
yes bro u r right prob solved thanks for best regards
Old 03-03-2010, 21:52   #13 (permalink)
Member: 247101
Thanks Meter: 3
Check the version or cable
lg ke970 error: can't run main loader kfkevin Infinity-Box 15 05-10-2010 16:34
sagem my150X error: can't run middle loader: 01 kfkevin Infinity-Box 1 04-28-2009 20:10
Vodafone 227 can't run main loader Artist Infinity-Box 5 05-28-2008 14:33
LG KE970 error: can't run main loader green bird Infinity-Box 1 02-16-2008 21:17
Page generated in 0.38124 seconds with 8 queries
