02-09-2010, 12:27 | #1 (permalink) |
No Life Poster Join Date: Mar 2007
Member: 468656 Status: Offline Thanks Meter: 76 | Huawei T202 After flash file on sp, phone was dead! Ang i was read full flash phone when i restored, it was fail file? what's problem INFI Team? |
02-09-2010, 12:45 | #4 (permalink) | |
also read this: C:\Program Files\InfinityBox\Documentation\FAQ\How_to_restore _full_flash_backup.txt | |
02-09-2010, 12:49 | #5 (permalink) |
Member: 468656 Status: Offline Thanks Meter: 76 | Here log flash with file on sp: Code: module v1.38 Device: Huawei-T202 "advanced chip detection" active Action: flash write write: Firmware T202_2009-04-27_firmware_En_Vn.80M.bin write: Flex/Customization T202_customization_VNMC82B101_452-02.80F.bin skip: Language Pack skip: FFS/File system skip: Images skip: Melody skip: Eeprom Checking data, wait... Boot ... Phone should be Switched OFF ! Press Power button now ! rom version: 0502 Connecting... booting... Boot done Check connection ... Check connection done Set baud ... 203125 Set baud done Check hardware ... flash: EC260600000000:FFFFFF00000000 flash: Samsung AMD/Fujitsu std [def 0008x002000 003Fx010000] 4Mb Check hardware done Read data ... reading Huawei-T202_eeprom_calibration-1... file saved: C:\Documents and Settings\phuong 311\Desktop\Huawei-T202_eeprom_calibration-1_20100209-184000.80E.bin Read data done Check data ... Check data done Write ... Area: Firmware flash: EC260600000000:FFFFFF00000000 Write: Firmware Area: Flex/Customization flash: EC260600000000:FFFFFF00000000 Write: Flex/Customization Write done Finished, time used: 5 min 59 sec Remove/Install battery now ! |
02-09-2010, 13:03 | #9 (permalink) | |
also check this: http://www.infinity-box.com/wiki/ind...ot_make_a_call | |
02-09-2010, 13:16 | #11 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | I am not sure that it was software problem. It may be hardware problem. did you tried to open phone and check it's hardware ? (honest answer required) |
02-09-2010, 13:38 | #12 (permalink) | |
Member: 468656 Status: Offline Thanks Meter: 76 | Quote:
I has just test hardware phone, it's not problem. If u have the phone Huawei T202 try flash with file on sp infi, and you has final result, true or fail as you talk... | |
02-09-2010, 16:44 | #13 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | If you think that it's sw problem you can us your original file: C:\Program Files\InfinityBox\Documentation\FAQ\How_to_restore _full_flash_backup.txt |
02-09-2010, 16:46 | #14 (permalink) |
Member: 468656 Status: Offline Thanks Meter: 76 | I take one peace! To flash but not pw too! Here is the file i backup, when i restored i had chosen file FW but has Note data error! Can INFI team fix file? Here file i was read another phone Huawei T202 and after that flash file on sp INFI so not PW on! http://www.4shared.com/file/21840200...awei-T202.html Last edited by duyphuong3000; 02-09-2010 at 16:51. |
02-09-2010, 19:29 | #15 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New flaash files uploaded in "main" support area mirror: T202_2009-02-28_firmware_En_Vn.80M.bin T202_customization_VNMC82B101_452-02_VNM.82.105.80F.bin |
after read flash file now set is fully dead | unlock & flash | Infinity-Box | 11 | 11-30-2008 22:18 |
v3x flash w/ original file for empty phone still dead | ttkul | Ultima Box Light | 1 | 09-16-2007 23:21 |
Z500 after flash reboot on formating file systems | GSM SNIPER | UST Pro II | 13 | 03-01-2007 02:04 |
