02-08-2009, 09:30 | #1 (permalink) |
Freak Poster Join Date: Jun 2008 Location: +92 345 5313170
Member: 802214 Status: Offline Sonork: 100.1573572 Thanks Meter: 95 | Huawei-T616i from jaaz unlock COM9 [VCP0] selected module v1.61 Device: Huawei-T161L Checking data, wait... Action: unlock unlock method-1 Boot ... loader: standard type: 4 Press and HOLD Power button now ! loading... next part... boot answer: 01 Release Power button now Boot Done Set Baud ... 460800 Set Baud Done Connecting ... flash: 0001:22C4 Connecting Done Check hardware ... Check hardware Done Check parameters ... Check parameters Done backup critical area ... reading eeprom-static... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-static_20090207-175012.B1E.bin loading data... wrong database file: C:\Program Files\InfinityBox\Pana01\z125_eep65535.cfg error: can't load database v.13 reading eeprom-security... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-security_20090207-175012.B1E.bin reading eeprom-complete... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_eeprom-complete_20090207-175014.B1E.bin reading additional data... file saved: C:\Program Files\InfinityBox\Pana01\Huawei-T161L_lock-area_20090207-175020.B1E.bin backup critical area Done Check memory ... lock found Check memory Done Write ... Erasing: lock-area Writing: lock-area Write Done Finished, time used: 33 sec Remove/Install battery now ! |
The Following 3 Users Say Thank You to .::adnangsm::. For This Useful Post: |
02-08-2009, 14:16 | #2 (permalink) | |
Member: 130995 Status: Offline Thanks Meter: 35,229 | Quote:
Each test report with attached logs is very important for us so we can see how is Infinity-Box software works, what is phone hardware configuration (f.e. flash chip type) and what is possible problems (so we will be able to fix it) and successfully done work. | |
Ist possible unlock Huawei E160 usb modem unlock | saajith | FuriousGold | 14 | 02-21-2010 03:48 |
new Huawei E1550 from Kyivstar cant unlock. | CLIFFORD25502 | FuriousGold | 8 | 02-18-2010 13:11 |
HELP Unlock Huawei c2905 - From Thailand | interphons | Various CDMA/TDMA Cell Phones | 3 | 12-10-2009 14:12 |
Huawei T211 readed & unlocked as Huawei T201 [GOOD WORK] | elcapitel | PolarBox 3 | 0 | 10-28-2009 21:15 |
HUAWEI E1550 from KIEVSTAR | sharkygsm | GSM / HSDPA Modems and Routers | 3 | 10-24-2009 01:55 |
