02-16-2016, 08:39 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: coast Age: 53
Member: 83397 Status: Offline Thanks Meter: 204 | Huawei y330-u01 failed read info and security repair Code: Operation : Repair Security [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Init Ok, waiting for phone ... Reading initial info, wait... Phone Info : BB : MT6572, E01 HW : HUAWEI72_WE_JB3_HSPA_HW SW : MOLY.WR8.W1315.MD.WG.MP.V15.P10 MM : 2000.00.00 VR : 1.0 SN : DU2PNL1589017599 Security Info : IMEI [1] : 866508025363719 IMEI [2] : 866508025363719 Read Ok! Update IMEI[1] to : 866508025352613 failed , record not exist or NVRAM damaged! Done! Elapsed: 00:01:03 Reconnect Power/Cable! Code: Operation : Check / Read Info [ v1.41 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 28 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... [DA_ERROR] : SECURITY_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:22 Reconnect Power/Cable! |
02-16-2016, 09:20 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | I remove those phones support from CM2 from 1.41. If need make some operations - can use 1.40 , but repair security over flash not supported. Too old phone. Will check and upload MAUI db today, if it exists. |
