08-08-2016, 13:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Huawei Y336-U02 no connect BB CPU : SC7731 Huawei Y336-U02 (Y3C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Start at : [8/8/2016 / 2:36:44 PM] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Open Port Failed! Reconnect Power/Cable! Finish at : [8/8/2016 / 2:36:52 PM] Start at : [8/8/2016 / 2:36:59 PM] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [8/8/2016 / 2:37:22 PM] Start at : [8/8/2016 / 2:37:31 PM] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : SPRD3 Sending FLASH FDL Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [8/8/2016 / 2:37:45 PM] Start at : [8/8/2016 / 2:38:11 PM] Operation : SP Unlock [ v1.20 ] Mode : DirectUnlock 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [8/8/2016 / 2:38:33 PM] Start at : [8/8/2016 / 2:38:42 PM] Operation : Read NV [ v1.20 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 21 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! Finish at : [8/8/2016 / 2:38:53 PM] all drivers are installed...I press boot keys still the same...mobile is network locked...I also wanted to read firmware for future service but failed... please help |
