02-17-2016, 07:48 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: peshawar
Member: 1282804 Status: Offline Sonork: 1636760 Thanks Meter: 82 | huawei y336-u02 sc7731 Boot failed! help me 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 14 ] Port Opened Sync... Initial Boot Failed! Reconnect Power/Cable! Finish at : [2/17/2016 / 1:26:22 AM] Start at : [2/17/2016 / 1:26:27 AM] Operation : Read NV [ v1.14 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 25 ] Open Port Failed! Reconnect Power/Cable! Finish at : [2/17/2016 / 1:26:35 AM] Start at : [2/17/2016 / 1:26:40 AM] Operation : Read NV [ v1.14 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 25 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [2/17/2016 / 1:27:45 AM] Start at : [2/17/2016 / 1:34:27 AM] Operation : Check/Read Info [ v1.14 ] |
The Following User Says Thank You to asif33 For This Useful Post: |
02-17-2016, 08:18 | #2 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Hello, Select Huawei_Y336_Y3C.sldr from C:\InfinityBox\CM2SPD\Models under Flash tab. Br. Infinity Box Support Team. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
02-17-2016, 09:48 | #6 (permalink) |
Freak Poster Join Date: Sep 2009 Location: another place
Member: 1128422 Status: Offline Thanks Meter: 67 | [QUOTE=asif33;11631412]u have to select sldr file in pac flash tab before read info/ fw, just select sldr file in folder models in cm2spd Last edited by tsabila; 02-17-2016 at 09:54. |
04-28-2017, 22:55 | #11 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | me too have this problem in my second phone. but first it is sucseed in first time by booting frim pac file and version. if. phone 109 in this phone have 110 and i diwnload. it from support. failure in boot. and all steps is correct. any suggestion |
