12-17-2015, 23:12 | #1 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Huawei Y336-U02 [SC7731s] : Service/Forensic/Flash/Security Code: SLDR Load Ok BB CPU : SC7731 Huawei Y336-U02 (Y3C) For disable SLDR - select PAC or other SLDR or re-select CPU in settings tab! Operation : Check/Read Info [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Y336-U02 Model Brand : HUAWEI Model Device: HWY336-U AndrVersion : 4.4.2 BaseBand CPU: Y336-U02 CompileDate : 1432150142 Project Ver : Y336-U02V100R001C567B108 Model Ext : HUAWEI Y336-U02 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:24 Reconnect Power/Cable! Code: Operation : Read PatternLock [ v1.08 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! Reading PatternLock ... Read Ok , decrypt PatternLock Sequence : 167294385 Done! Elapsed: 00:00:30 Reconnect Power/Cable! Code: Operation : Check/Read Info [ v1.08 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_HUAWEI_W15.19_P1_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 05-06-2015 20:08:44 Phone Security Info : IMEI [1] : 868007028392708 IMEI [2] : 868007028422968 BT_ADDR : 000000000000 Done Reconnect Power/Cable! Code: Operation : Repair Security [ v1.08 ] 1. Remove battery. Insert battery back 2. Insert cable 3. In case of SVC init problems - connect with hold "VolDown" button! ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitSvc Done Wait for phone... Sync... Phone Initial Info : Platform : MOCORTM_14B_TSHARK28_HUAWEI_W15.19_P1_Debug Project : sc7731g_CP0_modem HWInfo : sc7731g_CP0_modem Compile : 05-06-2015 20:08:44 Phone Security Info : IMEI [1] : 868007028392708 IMEI [2] : 868007028422968 BT_ADDR : 000000000000 Read Ok! Write new security data : IMEI1 : 868007028392708 IMEI2 : 868007028422968 Write done! Elapsed: 00:00:26 Reconnect Power/Cable! Code: Operation : Format File System [ v1.08 ] Settings : SmartFormat is On 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Checking Structure ... Detected eMMC Flash , Structure detect Ok! eMMC phone detected! Will use 'Safe Format' mode! Mount : /data Size : 0x000000008A500000 State : 0x0001 Mount : Size : 0x0000000009600000 State : 0x0001 Prepare Ok! Format Ok! Don't touch phone, until it fully bootup to "Welcome Screen"! Done! Elapsed: 00:00:33 Reconnect Power/Cable! Code: Loading : Y336-U02V100R001C567B108.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y336-U02V100R001C567B108 FastCheck : 0x5075870D Loading files ... File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo_1.bmp File : sysinfo.img File : customspc.img File : prodnv.img File : cache.img File : u-boot.bin File : dlstat.bin File : globalinfo.img File : SC7731_2341A_SB.xml Load Ok! Operation : Flash [ v1.08 ] ======= Flash Files set for flashing : [ MCU ] : Y336-U02V100R001C567B108.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y336-U02V100R001C567B108 File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo_1.bmp File : sysinfo.img File : customspc.img File : prodnv.img File : cache.img File : u-boot.bin File : dlstat.bin File : globalinfo.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 17 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! PMTManager : Load 0x16 records PMTManager : PMT Update Ok! Flashing now [FlashProc] : ERASE Current ID : ERASEUBOOT Current Part : uboot [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEDLSTAT Current Part : dlstat [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEGLOBALINFO Current Part : globalinfo [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : SPLLOADER Current File : u-boot-spl-16k.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : MODEM_W Current File : wmodem.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DSP_W Current File : wdsp.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOT Current File : boot.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : RECOVERY Current File : recovery.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSTEM Current File : system.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : USERDATA Current File : userdata.img Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : BOOTLOGO Current File : logo.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : FASTBOOT_LOGO Current File : logo_1.bmp Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : SYSINFO Current File : sysinfo.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CUSTOM Current File : customspc.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : FLASH Current Part : wruntimenv1 [FlashProc] : Ok! [FlashProc] : CODE Current ID : PRODNV Current File : prodnv.img Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : CACHE Current File : cache.img Flashing now ... [FlashProc] : Ok! [FlashProc] : ERASE Current ID : ERASEMISC Current Part : misc [FlashProc] : Ok! [FlashProc] : BOOTCODE Current ID : UBOOTLOADER Current File : u-boot.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : CODE Current ID : DLSTAT Current File : dlstat.bin Flashing now ... [FlashProc] : Ok! [FlashProc] : IMAGE Current ID : GLOBALINFO Current File : globalinfo.img Flashing now ... [FlashProc] : Ok! Elapsed: 00:03:31 Reconnect Power/Cable! |
The Following 11 Users Say Thank You to JayDi For This Useful Post: |
12-19-2015, 09:41 | #6 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | FW for Y336 (MultiLanguage) has been upload on support. Index of flashfiles/Huawei/ |
The Following 5 Users Say Thank You to JayDi For This Useful Post: |
12-20-2015, 09:56 | #10 (permalink) | ||
Freak Poster Join Date: Mar 2007 Location: TUNISIE
Member: 460934 Status: Offline Thanks Meter: 16 | Huawei Y336-U02 [SC7731s] : Service/Forensic/Flash/Security doesn't work for me plz Identify (boot) Quote:
03-30-2016, 12:27 | #12 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1153875 Status: Offline Thanks Meter: 47 | Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Open Port Failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Operation : Read FullFlash [ v1.16 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! help me |
05-31-2016, 10:43 | #14 (permalink) |
No Life Poster Join Date: Feb 2003 Location: TelServisHalo,Loznica, Serbia Age: 53
Member: 21365 Status: Offline Thanks Meter: 92 | Not working for me too Operation : Check/Read Info [ v1.18 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 42 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Boot failed! Reconnect Power/Cable! |
05-31-2016, 12:35 | #15 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Select Y336-U02 sldr and try again. Also charge your battery and use good cable. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
