11-20-2016, 12:50 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | Huawei y336-u02 write firmware Loading : Y336-U02V100R001C567B108.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y336-U02V100R001C567B108 FastCheck : 0x005075870D Loading files ... File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo_1.bmp File : sysinfo.img File : customspc.img File : prodnv.img File : cache.img File : u-boot.bin File : dlstat.bin File : globalinfo.img File : SC7731_2341A_SB.xml Load Ok! Operation : Flash [ v1.24 ] ======= Flash Files set for flashing : [ MCU ] : Y336-U02V100R001C567B108.pac CRVersion : BP_R1.0.0 PacCPUinfo : SC7731_2341A PacVersion : Y336-U02V100R001C567B108 File : fdl1.bin File : fdl2.bin File : wnvitem.bin File : wcnnvitem.bin File : u-boot-spl-16k.bin File : wmodem.bin File : wdsp.bin File : wcnmodem.bin File : boot.img File : recovery.img File : system.img File : userdata.img File : logo.bmp File : logo_1.bmp File : sysinfo.img File : customspc.img File : prodnv.img File : cache.img File : u-boot.bin File : dlstat.bin File : globalinfo.img 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 168 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable PickUp loaders from pac Reaches this level and tool freezes Tried with SPD tool and after over several minutes, it's still showing 'Downloading' at 'FDL1' > image below Tried also with ResearchDownload and below is the result. Tried several times but still same This file was download from here ?Huawei Detail? - Huawei Support - Huawei Consumer BG I tried sd card update but also no success Please I need help Last edited by busfield; 11-20-2016 at 12:56. |
The Following User Says Thank You to busfield For This Useful Post: |
11-20-2016, 13:01 | #2 (permalink) |
No Life Poster Join Date: Dec 2013 Location: India
Member: 2082450 Status: Offline Thanks Meter: 1,454 | Infinity CM2 SPD has some major changes in spd booting, so you need to follow this// Uninstall all the old spd drivers and install the latest driver from infinity support. then try... |
The Following User Says Thank You to chandanps18 For This Useful Post: |
11-20-2016, 14:11 | #3 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Bro, after following your procedure by uninstalling old driver and installing InfinityBox_update_CM2SPD_Drivers_v1.01, below is the result after connecting phone to pc |
The Following 2 Users Say Thank You to busfield For This Useful Post: |
11-20-2016, 14:23 | #4 (permalink) |
Member: 2082450 Status: Offline Thanks Meter: 1,454 | reinstall drivers again restart pc and try connecting the phone there would be no problem.... |
