02-17-2018, 09:00 | #1 (permalink) |
No Life Poster Join Date: Apr 2013 Location: $Kathmandu Nepal$
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,075 | Huawei Y5 2017 (Mya–L22) frp Remove Success Wait for phone... Phone found! [ 141 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741654FD432E376D9B1 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132D44F65B1D924E3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x2A3A2F400FD9F6BBC85C4422C096D073 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : HUAWEI ProdName : MYA-L22 ProdModel : MYA-L22 Device : HWMYA-L6737 AndroidVer: 6.0 MTKxCPU : MT6737T MTKxPRJ : Maya-L22C636B132 SECURITY : IMEI_SW [1] : 862XXXXXXXXXXX IMEI_SW [2] : 862XXXXXXXXXXX BTMAC Addr : 708A09131687 WiFi MAC : 708A090FBB27 MODEM : BaseBand : MT6735_S00_MOLY_LR9_W1444_MD_LWTG_MP_V94_P55_1_lwg _n EXTRA : LCD : Not info available LCD Res : 1280x720 TOUCH [0] : GT1XX LOCALE : en_US zh_CN zh_TW es_ES pt_BR ru_RU fr_FR de_DE tr_TR vi_VN ms_MY in_ID th_TH it_IT ar_EG hi_IN bn_IN ur_PK fa_IR pt_PT nl_NL el_GR hu_HU tl_PH ro_RO cs_CZ ko_KR km_KH iw_IL my_MM pl_PL es_US bg_BG hr_HR lv_LV lt_LT sk_SK uk_UA de_AT da_DK fi_FI nb_NO sv_SE en_GB hy_AM zh_HK et_EE ja_JP kk_KZ sr_RS sl_SI ca_ES Done! Elapsed: 00:00:32 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 141 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x9B NAND Flash : NOT INSTALLED eMMC Flash : 484A019061344741654FD432E376D9B1 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x80000000 DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , 2a4GA [eMMC] : FLASH_CID : 90014A484147346132D44F65B1D924E3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000003AB400000 [eMMC] : FLASH_UCP : 15028 MiB [eMMC 16 GiB] DEV RID : 0x2A3A2F400FD9F6BBC85C4422C096D073 INT RAM : 0x00020000 EXT RAM : 0x80000000 [2 GiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear FRP ( Google Reset Protection ) Clear Ok! Done! Elapsed: 00:00:28 Reconnect Power/Cable! YOUTUBE https://www.youtube.com/watch?v=BBno...ture=********* |
The Following 12 Users Say Thank You to raisalina For This Useful Post: |
02-17-2018, 21:40 | #3 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Here original factory DA_AGENT, attached. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! |
The Following 60 Users Say Thank You to Brka For This Useful Post: |
02-18-2018, 12:11 | #5 (permalink) |
Insane Poster Join Date: Mar 2015
Member: 2365304 Status: Offline Thanks Meter: 18 | Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v3.3001.00.00 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x93 NAND Flash : NOT INSTALLED eMMC Flash : 3000011133473631B5EE003249C1063B Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:19 Reconnect Power/Cable! |
02-19-2018, 02:48 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Attached. Enjoy ... b.r. Alex
The Following 20 Users Say Thank You to Brka For This Useful Post: |
02-19-2018, 08:28 | #8 (permalink) |
Member: 1911970 Status: Offline Sonork: 9741081772 Thanks Meter: 2,075 | |
The Following User Says Thank You to raisalina For This Useful Post: |
06-02-2018, 06:46 | #13 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: bangladesh Age: 34
Member: 1104393 Status: Offline Sonork: 100.1603062 .::RONY::.. Thanks Meter: 130 | Quote:
06-04-2018, 09:45 | #14 (permalink) |
No Life Poster Join Date: Feb 2007 Location: Mongolia
Member: 444532 Status: Offline Sonork: 100.1576960 Thanks Meter: 214 | i copyed to boot folder, but not work, why? 04.06.2018 / 14:28:40 ================================================== ======= Card found : S/N : 09xxxxxx , v0136 Chinese Miracle II [MTK module] v 1.58 Start at : [04.06.2018 / 14:29:11] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 27 ] Sync... Inital Boot Ok! BB_CPU_PID : 6735 BB_CPU_NME : [MediaTek] MT6735_S00 BB_CPU_EXT : 0xCA00 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x01000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : SIGNED with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... [DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED Boot Error! Operation Failed Elapsed: 00:00:36 Reconnect Power/Cable! Finish at : [04.06.2018 / 14:29:48] |
06-04-2018, 15:14 | #15 (permalink) | |
Member: 2365304 Status: Offline Thanks Meter: 18 | Quote:
https://ibb.co/i0oAso https://www.youtube.com/watch?v=JroXoZzK_-I Last edited by hard drive; 06-04-2018 at 15:20. | |
The Following User Says Thank You to hard drive For This Useful Post: |
