Old 03-03-2016, 08:06   #1 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 639
huawei y511-u30 eror while flash
Card found : S/N : 0D63E285 , v0130
Chinese Miracle II [MTK module] v 1.41
Scatter Load Ok , BaseBand : MT6572 , Project : wt98511 , Storage : EMMC
Files found : 11 , Set to Flash : 10
Ready to Flash!
Operation : Flash [ v1.41 ]
======= Flash
Wait for phone...
Phone found! [ 102 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
BootLdrSS : NORMAL with SPRELOADER
Processing DA stage
DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 90014A4834473164048601A43331C1B1
Initialize Memory ...
DRAM configured from ScatFW!
DRAM initialize passed!
DRAM size : 0x20000000
eMMC FlashIC initialized
[eMMC] : FLASH_VEN : 0x90 , OEM : 014A
[eMMC] : FLASH_INF : [HYNIX] , d1G4
[eMMC] : FLASH_CID : 90014A4834473164048601A43331C1B1
[eMMC] : FLASH_BRT : 0x00200000 , 0x00200000 , 0x00200000
[eMMC] : FLASH_LEN : 0x00000000E7000000
[eMMC] : FLASH_UCP : 3696 MiB [eMMC 4 GiB]
DEV RID : A9F8396EE342D116E5E4BE78635A1A2C
INT RAM : 0x00020000
EXT RAM : 0x20000000
BOOT TYPE : EMMC_FLASH_BOOT
SOC VERIFY : C1
Boot Ok!
ScatCFG : BaseBand : MT6572 , Project : wt98511 , Storage : EMMC
Setting : AFF verify : Enabled
Setting : HW verify : Enabled
Switching to HSUSB
HSUSB Init Ok
BL : Check HW compatibility
BL : Check eMMC compatibility
BL : BatteryLevel : 4064 mV
BL : BatteryLevel Ok
BL : Flash Pre-Erase
Total blocks to Erase : 2
Erase : 0x0000000000600000-0x0000000000100000
Erase : 0x0000000002300000-0x0000000094840000
Flash Pre-Erase Done, time used : 00:00:22
SecCfg Passed , 1799
BMT remark not need. Will skip
Sending Preloader ...
Use : preloader_wt98511.bin
Preloader Sent , Init passed
PartCount : 0013
Update PMT by user request
Repartition Failed! Break! Something wrong with HW or BL (FirmWare)
Operation Failed
Elapsed: 00:01:28
Reconnect Power/Cable!
Old 03-03-2016, 08:51   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 6,975
Hello,
What's phone condition?Make HW Test and also try with other version firmware.
Br.
Infinity Box Support Team.
Old 03-03-2016, 11:33   #3 (permalink)
umarmsn's Avatar
Member: 616909
Sonork: 1672125
Thanks Meter: 639
Originally Posted by PASSIONATE_BOYS View Post
Hello,
Br.
oh ok
phone condition was hang but when i try to flash getting this problem
Old 03-03-2016, 11:41   #4 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,597
It mostly seems as ReadOnly eMMC.
Flash IC test in CM2MTK can verify that and tell exactly result.
Page generated in 0.29046 seconds with 7 queries
