Old 03-10-2016, 19:57   #1 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
how to force erased wrong flased set
Gives error EMI cfg not found
Old 03-10-2016, 20:10   #2 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hi ,
Plz post log and also if u have correct firmware do init preloader then do full flash
Sent from my S_plus using Tapatalk
Old 02-13-2017, 03:16   #3 (permalink)
1R0niC's Avatar
Member: 2109200
Thanks Meter: 40
same issue here
Originally Posted by princesaddam View Post
Hi ,
Plz post log and also if u have correct do init preloader then do full
all my telcel firmware
log
User selected Preloader file : preloader_ztenj72_we_72_m536_kk.bin
Operation : Init Preloader [ v1.58 ]
Supported HW by Preloader :
FlashID [0] CID : 700100533130303034 , Name : S10004 , Vendor : 70 , [KINGSTON]
FlashID [1] CID : FE014E503058585858 , Name : P0XXXX , Vendor : FE , [MICRON]
FlashID [2] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON]
FlashID [3] CID : 700100454534454134 , Name : EE4EA4 , Vendor : 70 , [KINGSTON]
FlashID [4] CID : FE014E50314A393448 , Name : P1J94H , Vendor : FE , [MICRON]
FlashID [5] CID : 7001004D4D43303447 , Name : MMC04G , Vendor : 70 , [KINGSTON]
FlashID [6] CID : 700100533130303034 , Name : S10004 , Vendor : 70 , [KINGSTON]
Wait for phone...
Phone found! [ 109 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6572
BB_CPU_NME : [MediaTek] MT6572_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x88
NAND Flash : NOT INSTALLED
eMMC Flash : 1501004E4A325A4D420281C6C4CC33EF
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
Firmware selected, but it NOT compatible!
Boot Error!
Operation Failed
Elapsed: 00:00:04
Reconnect Power/Cable!
Old 05-02-2017, 06:50   #4 (permalink)
free2ulam's Avatar
Member: 1284863
Thanks Meter: 51
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BB_CPU_NME : [MediaTek] MT6583|6589_S00
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
Running DA ver.3.2 on BBID : 0x86
eMMC Flash : 484A019064314734A2008604DF809C71
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:05
The Following User Says Thank You to free2ulam For This Useful Post:
Old 05-02-2017, 07:05   #5 (permalink)
Member: 608516
Sonork: 100.1607007
Thanks Meter: 123
Wait for phone...
Phone found! [ 42 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6583
BromVer : 0x0005
BLVersion : 0x00FE
Processing DA stage
ErroCode : 0x2003
EMICFG_NOT_FOUND
Boot Error!
Operation Failed
Elapsed: 00:00:05
Emmc problem
Sent from my Lenovo K50a40 using Tapatalk
Old 05-02-2017, 08:22   #6 (permalink)
Nasir Mobiles's Avatar
Member: 355782
Thanks Meter: 1,265
init compatible preloader then phone will act normally.
for force you need to find boot pin / kolo point / colo / aka gold point etc.
Old 05-02-2017, 13:08   #7 (permalink)
Member: 1677653
Thanks Meter: 2,769
Can someone explain with good illustration.. I also have the same issue here
Page generated in 0.17199 seconds with 8 queries
