03-02-2015, 11:46 | #1 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Bulgaria/China Age: 58
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | HUAWEI Y511-U30 read factory flash problem Chinese Miracle II [MTK module] v 1.13 Operation : Read Flash [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048607A30759A05F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:45 Reconnect Power/Cable! Operation : Read Flash [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 9 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048607A30759A05F DA Stat : v4.2 on BBID : 0x88 Configure emi settings Error : DA init Failed! Error code : 0x5 Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
03-02-2015, 13:10 | #4 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: proud to be an INDIAN Muslim Age: 39
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | Quote:
http://forum.gsmhosting.com/vbb/f296...l#post10895101 or try with cm2 1.12 version Last edited by rehmani; 03-02-2015 at 13:17. | |
03-02-2015, 18:23 | #6 (permalink) |
No Life Poster Join Date: Nov 2008 Location: ĦĦInFiNiTy CM2 For EvER!!
Member: 901711 Status: Offline Sonork: 100.1606138 Thanks Meter: 427 | please wait...then I do a backup or copy in FSF if i can.... I make a copy in FSF for Y520-U03 and perfect.. i try to make in Binary for other tools like Mir@cl.. and Av@t... but fail.. (( maybe need unlock bootloader to make it)). So i try whit CM2 1.12 and do perfect!!! |
03-03-2015, 09:19 | #7 (permalink) |
Member: 391664 Status: Offline Sonork: Python Thanks Meter: 1,063 | MTK6575 i8552 galaxy win read factory flash failed read full flash ok :( ? Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0045 , OEM : 0100 [eMMC] : FLASH_INF : G40ME [eMMC] : FLASH_CID : 45010053454D3034479033874AAEAF73 [eMMC] : FLASH_LEN : 0x00000000EC000000 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Info read not done Erased phone or unsupported FlashIc? Done! Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Read Flash [ v1.13 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 16 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6575 BB_CPU_HW : CB00 BB_CPU_SW : 8A00 BB_CPU_SB : E201 BB_CPU_NM : [MediaTek] MT6575_S00 Processing BROM stage i2c Init : 00000000 SpeedSet : 0000 VChrgSet : 0x28 , BatStat : 0x02 WD Disable stat : 0x0000 BLVersion : 0x01 SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Stat : v3.2 on BBID : 0x84 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0015 , OEM : 0100 [eMMC] : FLASH_INF : M00SJ [eMMC] : FLASH_CID : 1501004B4A5330304D03732C33FB6097 [eMMC] : FLASH_LEN : 0x00000000E9000000 INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Conent now ... Read Ok , collect info ProdName : GT-I8552 ProdModel : GT-I8552 Device : GT-I8552 AndroidVer: 4.1.2 MTKxCPU : MT6575 MTKxPRJ : ALPS.JB.MP.V1.16 Saved to : C:\InfinityBox\CM2MTK\Flash\MT6575__GT-I8552__ALPS.JB.MP.V1.16__Android_4.1.2__20140926_0 12308.ispff Done! Elapsed: 00:29:54 Reconnect Power/Cable! |
03-03-2015, 10:13 | #8 (permalink) |
Member: 333199 Status: Offline Sonork: may i help u just pm me Thanks Meter: 2,405 | here is links.......... MT6572__HUAWEI__HUAWEI Y511-U30__HWY511-U__4.2.2__ALPS.JB3.MP.V1.part1 - Download - 4shared - ABDUL MUSEEB REHMANI MT6572__HUAWEI__HUAWEI Y511-U30__HWY511-U__4.2.2__ALPS.JB3.MP.V1.part2 - Download - 4shared - ABDUL MUSEEB REHMANI MT6572__HUAWEI__HUAWEI Y511-U30__HWY511-U__4.2.2__ALPS.JB3.MP.V1.part3 - Download - 4shared - ABDUL MUSEEB REHMANI MT6572__HUAWEI__HUAWEI Y511-U30__HWY511-U__4.2.2__ALPS.JB3.MP.V1.part4 - Download - 4shared - ABDUL MUSEEB REHMANI |
