09-04-2015, 15:12 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: In My Limit
Member: 610502 Status: Offline Sonork: 100.1618428 Thanks Meter: 161 | HUAWEI Y511-U30 Showing Strange Logs... http://forum.gsmhosting.com/vbb/f296...l#post11265528 LOGS:\ HUAWEI Y511-U30 LOGS: Card found: S/N Chinese Miracle II [MTK module] v 1.28 Operation : Check / Read Info [ v1.28 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 101 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6572 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0000 BB_CPU_NM : [MediaTek] MT6572_S00 Processing BROM stage BLVersion : 0xFE SecCfgVal : 0x00000000 BromVersion : 0x05 BLVersion : 0xFE Preloader Status : Not active (Erased) Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v7.1533.03 NAND_ID : 00B000B000B000B000B000B000B00000 eMMC_ID : 00000000000000000000000000000000 DA Stat : v4.2 on BBID : 0x88 DRAM not initialized , configure DRAM Settings DRAM EmiReq Ok , 0x00A8 Error : DA init Failed! Error code : 0x5 LErr : EMICFG_NOT_FOUND Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! WHAT THIS ERROR ABOUT ANY IDEA? |
09-05-2015, 05:49 | #4 (permalink) |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | don't know more about this but i get same problem here http://forum.gsmhosting.com/vbb/f296...usion-1956075/ |
09-05-2015, 06:10 | #5 (permalink) | |
No Life Poster Join Date: May 2012 Location: InfinityBox CM2
Member: 1763238 Status: Offline Thanks Meter: 370 | Quote:
Micromax A082 hang on logo my problem solved just some heat CPU and eMMC ic. | |
