03-18-2016, 19:28 | #1 (permalink) |
Cheater -Don't Deal with him- Join Date: Apr 2006 Age: 36
Member: 265129 Status: Offline Thanks Meter: 281 | Huawei y520-u22 dead Phone found! [ 13 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1552.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110222542544B275 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND Firmware selected, but it NOT compatible! Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! need flash file Infinity team please help me |
03-20-2016, 08:44 | #5 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 894846 Status: Offline Sonork: ajmal Thanks Meter: 111 | y520-u22, v100r001c328b112 this file can only help u but make sure it has to be flash tool file Y520-U22_V100R001C328B111_Firmware_The Middle East Africa_Others_Android 4.4.2_NA_05021RAV aslo chek this |
03-20-2016, 18:51 | #6 (permalink) | |
Member: 265129 Status: Offline Thanks Meter: 281 | Quote:
still same need B113 firmware. if any one have please give me link thanks br Faizan | |
01-12-2017, 15:20 | #9 (permalink) |
No Life Poster Join Date: Feb 2006 Location: CAIRO Age: 37
Member: 237684 Status: Offline Thanks Meter: 66 | me too flash with all version with infinity and spflash tool erase flash file by infinity also erase preloader vibrate and huawei logo after search find this flash but its paid https://firmware.gem-flash.com/index...e-info&id=9984 can any one get the link free |
01-14-2017, 18:05 | #11 (permalink) |
Member: 237684 Status: Offline Thanks Meter: 66 | Operation : HW Test [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 18 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473164040301A26F8BB10B Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164040301A26F8BB10B [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x313968DF34DEF2187AECB4A420D81C17 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Processing Miscellaneous test MSC : BatteryLevel : 3909 mV [Processing] FlashMemory Read-Write test [eMMC] : [HYNIX] , d1G4 , 0xE9000000 , 3728 MiB [eMMC] : CID : 90014A4834473164040301A26F8BB10B [eMMC] : MODE : SQ-WR [PASSED] : eMMC RW Check #1 Ok! [eMMC] : MODE : RA-WR [PASSED] : eMMC RW Check #2 Ok! [eMMC RO CHECK] : eMMC Ok! READ-WRITE Passed! [Processing] RAM Read-Write test [DRAM] : 0x20000000 , 512 MiB [DRAM] : ADDRESS BUS test [PASSED] : Bus Count : 0x1C [DRAM] : DATA BUS test [PASSED] : Bus Count : 0x1F [DRAM] : PATTERN test [PASSED] : PATTERN Ok [DRAM] : INCDEC test [PASSED] : INCDEC Ok All Done! Done! Elapsed: 00:01:34 Reconnect Power/Cable! |
