05-02-2016, 15:58 | #1 (permalink) |
Freak Poster Join Date: Jul 2007 Location: Rawalpindi Pakistan Age: 37
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Huawei Y520-u22 flashing error but when i flash i face error like below 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111028660A93DB2C1 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111028660A93DB2C1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : C810D5D57978F69A19D0EE57A7A3C0BB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled Switching to HSUSB HSUSB Init Ok BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:29 Reconnect Power/Cable! |
05-03-2016, 08:23 | #3 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Uganda Age: 45
Member: 96478 Status: Offline Sonork: 100.1674604 Thanks Meter: 1,420 | @Jaydi why that happens? Even if you read firmware from that very phone and you want to write it back. THIS FIRMWARE WILL KILL PHONE......... Sometimes it happens in some phones. |
05-03-2016, 09:00 | #5 (permalink) | |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | Quote:
any body have this kind of file readed with cm2 | |
05-03-2016, 09:26 | #6 (permalink) |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | i already uncheck hw check by doing this phone flashed but not powering on. i need this kind of flash file much this info and then give me link thankx model huawei y520-u22 Wait for phone... Phone found! [ 23 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111028660A93DB2C1 Initialize Memory ... DRAM configured from IDB! DRAM initialize passed! DRAM size : 0x20000000 eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111028660A93DB2C1 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : C810D5D57978F69A19D0EE57A7A3C0BB INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... USBDL : Init HSUSB Ok! |
05-03-2016, 14:27 | #7 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
It because CM2 warn you about possibility to kill it, but you told - it 100% Ok and 200% tested. Now you need find correct version. | |
05-11-2016, 13:25 | #8 (permalink) | |
Friends my phone still dead. now i am sharing pcb picture plz check and give me solution i tried more hen 15 files but i got this error i did with merapi and sp but not success when i am untick hw check in cm2 phone flashed but now powering on. | |
05-19-2016, 22:09 | #13 (permalink) | |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | Quote:
If still dead then use this preloader with readed or any OK firmware..after flash your phone will be power on normally | |
The Following User Says Thank You to danishalnoor For This Useful Post: |
05-20-2016, 09:19 | #14 (permalink) |
Member: 541180 Status: Offline Sonork: 100.1626680 Thanks Meter: 147 | after much straggle my phone power on back and working fine now luckily a working phone come with me i read firmware from this phone with cm2 and flash my dead phone with this firmware now its ok below is logo check Code: Operation : Read Flash [ v1.47 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 4 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1612.01.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A4834473261110254489869B299 Initialize Memory ... DRAM already initialized by Preloader eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A4834473261110254489869B299 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 45A8BD8A584F1CBC8C3D78D6F8CB7836 INT RAM : 0x00020000 EXT RAM : 0x20000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Reading Flash Content now ... Brand : HUAWEI ProdName : Y520-U22 ProdModel : HUAWEI Y520-U22 Device : HWY520-U AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP6.V1 [Read Ok] : preloader_ckt72_we_72_kk.bin [Read Ok] : MBR [Read Ok] : EBR1 [Read Ok] : lk.bin [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : secro.img [Read Ok] : logo.bin [Read Ok] : system.img [Make Ok] : cache.img [Make Ok] : userdata.img [ScatCFG] : MT6572 / V1.1.1 / ckt72_we_72_kk / EMMC Android Info saved MAUI Meta DB saved HWConfig Info saved FW Size : 951 MiB Scatter saved to : C:\Users\Qaiser\Desktop\MT6572__HUAWEI__HUAWEI_Y520-U22__HWY520-U__4.4.2__ALPS.KK1.MP6.V1\ All done! Done! Elapsed: 00:05:31 Reconnect Power/Cable! if any body need this file i can upload and share with my gsmhosting friends thanks to my all those friend who try to help me. |
05-20-2016, 12:28 | #15 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: Dera Ismail Khan (KPK) Pak
Member: 613449 Status: Offline Sonork: 100.1614074 Thanks Meter: 634 | Quote:
thanks to my all those friend who try to help me.[/QUOTE] Please upload this file I Have Same problem | |
