03-06-2017, 04:25 | #1 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 470646 Status: Offline Thanks Meter: 58 | YU Yureka AO5510 not supported Operation : Identify [ v1.10 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 00BCA6E2 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 600FCAF7B5C09323276DB3B40F277932 ID_BLOCK_L : FD95EC7E21DA1FEA36482A00308577E7 Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
04-28-2017, 15:30 | #2 (permalink) |
Super Moderator Join Date: Jul 2009 Location: .:India:.
Member: 1078689 Status: Offline Sonork: 100.1626373 Thanks Meter: 2,826 | I Have Hard Bricked Cellphone With Same Error. Operation : Identify [ v1.11 ] Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_S : 00838627 Error : Device stuck in S-EDL! S-EDL : Reset power. Use BootJIG ( probably it is time to seek TP ) Reconnect Power/Cable! Operation : Identify [ v1.11 ] With Test Point. Code: 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 610 [MSM8936] ID_BLOCK_S : 00838627 ID_BLOCK_I : 0090B0E1 ID_BLOCK_L : 3B4A8FACF09BDE987C20F4F1426C3269 ID_BLOCK_L : 344E27B7FA13D8236F73F3CFF74C4E3E Use CM2 Internal Loader Error : Prepare target failed! Unsupported SecureType! Send log and report.log to support! Include device info also! Reconnect Power/Cable! |
