06-27-2016, 11:21 | #1 (permalink) |
No Life Poster Join Date: Feb 2011 Location: Android Modding
Member: 1507693 Status: Offline Thanks Meter: 131 | Huawei y520-u22 storage problem here are the logs: INIT BOOTLOADER User selected Preloader file : preloader_ckt72_we_72_kk.bin Operation : Init Preloader [ v1.49 ] Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [4] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111024E4534D5B21F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111024E4534D5B21F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x22674773081ABBA7EF8A43BB9DB947E8 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! SecCfg Passed , 1799 BL : BBID supported by BootLoader! Supported HW by Preloader : FlashID [0] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [1] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [2] CID : 110100303034473930 , Name : 004G90 , Vendor : 11 , [TOSHIBA] FlashID [3] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [4] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] STORAGE : BL NOT support this eMMC! Select Correct One! Done! Elapsed: 00:00:09 Reconnect Power/Cable! FLASHING Scatter Load Ok , BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC Files found : 11 , Set to Flash : 10 Created by Infinity-Box (c) Chinese Miracle II (c) 2016 Device Brand : HUAWEI Device Model : HWY520-U Device CPU : MT6572 Device IntName : Y520-U22 Device Version : 4.4.2 Device Compile : 12/9/2014 1:27:43 AM Device Project : ALPS.KK1.MP6.V1 Device ExtInfo : HUAWEI Y520-U22 Ready to Flash! Operation : Flash [ v1.49 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 30 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A483447326111024E4534D5B21F Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A483447326111024E4534D5B21F [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x22674773081ABBA7EF8A43BB9DB947E8 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : ckt72_we_72_kk , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! |
The Following User Says Thank You to Fragga For This Useful Post: |
06-27-2016, 11:33 | #2 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | there are two type of preloader as u r mobile show this one. User selected Preloader file : preloader_huaqin72_cwet_1a_kk.bin Operation : Init Preloader [ v1.51 ] Supported HW by Preloader : FlashID [0] CID : 45010053454D303447 , Name : SEM04G , Vendor : 45 , [SANDISK] FlashID [1] CID : 90014A483447316404 , Name : H4G1d , Vendor : 90 , [HYNIX] FlashID [2] CID : 1501004E35585A4D42 , Name : N5XZMB , Vendor : 15 , [SAMSUNG] FlashID [3] CID : 90014A483447326111 , Name : H4G2a , Vendor : 90 , [HYNIX] |
06-28-2016, 09:09 | #4 (permalink) | |
Member: 1507693 Status: Offline Thanks Meter: 131 | Quote: bro thanks for the file, it flashing, but after finish the phone is not switching on, when i connect charger the phone shows battery which is almost full, but not power on, , another thing i noticed, all the files are in .bin format, is system is not supposed to be system.img? just wondering, if you another file please help | |
06-28-2016, 09:54 | #5 (permalink) |
Member: 1507693 Status: Offline Thanks Meter: 131 | Scatter Load Ok , BaseBand : MT6572 , Project : mtk_android , Storage : EMMC Files found : 10 , Set to Flash : 9 Ready to Flash! Operation : Flash [ v1.49 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 43 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with SPRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1620.10.01 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 90014A48344732611102AA345C9DB279 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x90 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , a2G4 [eMMC] : FLASH_CID : 90014A48344732611102AA345C9DB279 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00400000 [eMMC] : FLASH_LEN : 0x00000000E9000000 [eMMC] : FLASH_UCP : 3728 MiB [eMMC 4 GiB] DEV RID : 0x99A1BE3942E37D1C4318F76634CBE264 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : mtk_android , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC supported by BootLoader! BL : BatteryLevel : 3816 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 3 Erase : 0x0000000000C00000-0x0000000000100000 Erase : 0x0000000001000000-0x0000000000500000 Erase : 0x0000000002900000-0x00000000E4700000 Flash Pre-Erase Done, time used : 00:00:10 SecCfg Passed , 1799 BMT remark not need. Will skip Sending Preloader ... Use : preloader.bin Preloader Sent , Init passed SecCfg Passed , 1799 PartCount : 0013 Update PMT by user request Repartition Done! Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : NVRAM Image Flash Ok Flash now : UBOOT Image Flash Ok Flash now : BOOTIMG Image Flash Ok Flash now : RECOVERY Image Flash Ok Flash now : SEC_RO Image Flash Ok Flash now : LOGO Image Flash Ok Flash now : ANDROID Image Flash Ok Flash Write Done, time used : 00:02:21 Processing : Verify Verify Passed : MBR Verify Passed : EBR1 Verify Passed : NVRAM Verify Passed : UBOOT Verify Passed : BOOTIMG Verify Passed : RECOVERY Verify Passed : SEC_RO Verify Passed : LOGO Verify Passed : ANDROID Data Verify Done, time used : 00:00:43 Update Mirror PMT Update Done! Update RomInfo done Done! Elapsed: 00:03:32 Reconnect Power/Cable! WHEN I FLASH WITH SP Flash Tool v5.1352.01 SAYS ERROR INVALID ROM, but when I flash with SP_Flash_Tool_v3.1312.0.139 PHONE SWITCH ON BUT SHOWS ERROR (Your Mobile phone has occured critical problem and need reset mobile to fix. ) then at the botton gives two options ( Reset your phone and do nothing and reboot ) if i select reset phone it takes many hours on PLEASE WAIT...., and if I select DO NOTHING AND REBOOT it just reboot and come back to the same screen again !!! |
