02-21-2017, 08:39 | #1 (permalink) |
Freak Poster Join Date: Jul 2016
Member: 2604648 Status: Offline Thanks Meter: 346 | HUAWEI Y530-U00 MSM8610 Read FW Done 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x10] ID_BLOCK_S : 0164C329 ID_BLOCK_I : 008110E1 ID_BLOCK_L : BE463CDA75E1EE19C6BB55BA85DC5474 ID_BLOCK_L : 3F56F85344CF7FF409E4A9666C839DBE Use CM2 Internal Loader Loader Sent! Initializing ... Running FireHose on BBID : MSM8x10 , FLASH : eMMC , mVER : 1 ExtInfo : 0x0000C000/0000C000/00001000/00001000 Boot Ok! Brand : Huawei ProdName : Y530-U00 ProdModel : HUAWEI Y530-U00 Device : hwY530-U00 AndroidVer: 4.3 Manufact. : HUAWEI QLMxCPU : MSM8610 DevInfo : MSM8610__HUAWEI__Huawei__ANDR_v4.3__HUAWEI_Y530-U00__hwY530-U00__Y530-U00 Reading Flash Content ... [Read Ok] : gpt_main0.bin [Read Ok] : sbl1.mbn [Read Ok] : deploy.mbn [Read Ok] : rpm.mbn [Read Ok] : tz.mbn [Read Ok] : emmc_appsboot.mbn [Read Ok] : oemdata.bin [Read Ok] : NON-HLOS.bin [Read Ok] : fs_gc.img [Read Ok] : persist.img [Read Ok] : boot.img [Read Ok] : recovery.img [Read Ok] : cust.img [Read Ok] : cache.img [Read Ok] : misc.img [Read Ok] : system.img [Read Ok] : userdata.img [Read Ok] : gpt_backup0.bin Android Info saved! Read finished! Configuration : MSM8x10 / eMMC Firmware Size : 1373 MiB Done! |
The Following 6 Users Say Thank You to buffer2k11 For This Useful Post: |
02-21-2017, 19:43 | #5 (permalink) | |
No Life Poster Join Date: Jan 2009 Location: GSM Age: 44
Member: 940222 Status: Offline Thanks Meter: 439 | Quote:
if it big size upload rom without systeme .img | |
03-04-2017, 05:12 | #8 (permalink) | |
No Life Poster Join Date: Aug 2006 Location: BHARAT
Member: 327043 Status: Offline Sonork: 100.1587811 Thanks Meter: 1,514 | Quote:
total firmware size is 1373MB but as i see system image size is more then 1GB and User data also more the 1GB then its 1373 MB file size is ok ? | |
03-14-2017, 08:30 | #12 (permalink) | |
Freak Poster Join Date: Oct 2008 Location: Bulgaria
Member: 877235 Status: Offline Sonork: vasilbojilov Thanks Meter: 199 | Quote:
HERE: https://yadi.sk/d/xnSSnVpk3Fknkv | |
The Following 5 Users Say Thank You to vasko_bojilov For This Useful Post: |
06-28-2017, 00:29 | #13 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | Hello, how to enter EDL mode on this phone if it is bootlooping? so, no adb mode available any trick or TP pls ? already tried EDL cable... |
10-21-2017, 01:21 | #15 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,784 | Quote:
(short it with tweezers, insert usb cable, remove tweezers.). Repair procedure : - Read full flash with CM2 QLM (read "extra data also") - Unpack desired update.app with Huawei Update Extractor - Use memory tool to write important partitions via Memory Tool or - Replace image files you unpacked in readed flash image, then re-flash phone b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
The Following 2 Users Say Thank You to Brka For This Useful Post: |
