Old 11-24-2016, 07:06   #1 (permalink)
Member: 431334
Thanks Meter: 5
Huawei y6 pro TIT -U02 Dead with CM2
Huawei y6 pro TIT -U02 Dead after try to read info CPU MTK 6735P
Old 11-24-2016, 09:28   #2 (permalink)
PASSIONATE_BOYS's Avatar
Member: 541591
Sonork: 100.1611509
Thanks Meter: 7,361
Hello,
Read info not touch any phone data.
Post logs and check phone.
Br.
Infinity Box Support Team.
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post:
Old 11-24-2016, 10:53   #3 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 735
try hold both volume keys and power for 1 minute
maybe you phone need to reboot
i did test read info to but nothing happens
The Following User Says Thank You to sky73 For This Useful Post:
Old 11-24-2016, 11:49   #4 (permalink)
Member: 2103284
Thanks Meter: 15
As far as I know, and I can see inside Huawei Y6 Pro TIT-U02 have CPU - MT6582V 1531-WAHHAH
And any operation with cm2mtk can't make phone dead. At least for my phone instance TIT-U02
As say JayDi in my thread
Originally Posted by JayDi View Post
Hello.
It uses secured signed mode , not got anything yet for those devices.
The Following User Says Thank You to poza89 For This Useful Post:
Old 11-25-2016, 07:10   #5 (permalink)
Member: 431334
Thanks Meter: 5
but the phone is new and good condition
Old 11-25-2016, 07:58   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Hello sir,
*Where is log for Cm2 read Info then Dead?
*Did you agree that your phone CPU is MT6582 NOT (MTK 6735P )as you Said?
Results?
The Following User Says Thank You to Kirumira For This Useful Post:
Old 11-25-2016, 08:35   #7 (permalink)
princesaddam's Avatar
Member: 1010626
Sonork: using fb
Thanks Meter: 735
Hello,
this type model have bug in it only means huawei company have prblm u need a working preloader just do int preloader its not cm2 fault its Huawei prblm
Old 11-25-2016, 12:11   #8 (permalink)
Member: 431334
Thanks Meter: 5
Originally Posted by Kirumira View Post
Hello sir,
Results?
read info
Operation : Check / Read Info [ v1.57 ]
Wait for phone...
Phone found! [ 145 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BB_CPU_NME : [MediaTek] MT6582_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer : 0x0005
BLVersion : 0x00FE
PreLoader : NOT Active [ Erased ]
Processing DA stage
Sending and initialize DA ...
Running DA ver.4.2 on BBID : 0x87
NAND Flash : NOT INSTALLED
eMMC Flash : 150100513331334D42061BABA70D3375
Initialize Memory ...
[DA_ERROR] : DRAM Configure failed!
ErroCode : 0x2003
EMICFG_NOT_FOUND
TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT!
Boot Error!
Operation Failed
Elapsed: 00:00:04
Reconnect Power/Cable!
Old 11-25-2016, 18:41   #9 (permalink)
Member: 2103284
Thanks Meter: 15
How you did that? I try many tryes conect phone to cm2 - it was error on soft, but phone still normally working...
Unfortunately at thise moment, there no any solutions((
Even no root on this device (tit-u02 with mt6582) even with unlocked bootloader...
Just only wait
Отправлено с моего HM 1SW через Tapatalk
Old 06-22-2017, 13:15   #10 (permalink)
Member: 943186
Thanks Meter: 8
i have Huawei TIT-U02 i gues it stucked on flash mode because i can see MTK comport on device Manager when i connect battery,before i press bootkey its going to boot mode itself.on screen it doesnot show anything its temporary dead.any help?
Old 06-22-2017, 13:57   #11 (permalink)
Member: 2103284
Thanks Meter: 15
Try not hold any key, just connect and then post logs. What will be result.
Отправлено с моего Redmi 4 через Tapatalk
Old 09-21-2017, 11:50   #12 (permalink)
Member: 2119579
Thanks Meter: 44
Huawei TIT-U02
Hello guys, I try to read firmware fro this model I get an error and here is the log:
Operation : Read Flash [ v1.58 ]
Wait for phone...
Phone found! [ 648 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6582
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
DA Select done, will use SecMode DA
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:07
Old 10-22-2017, 06:46   #13 (permalink)
Member: 2709143
Sonork: Henkey
If you want to root your Huawei Y6 Pro TIT-U02 then finally there's a tutorial. Follow the link:
problem-solver. ml/root-huawei-y6-pro-tit-u02/
The Following User Says Thank You to Henkey For This Useful Post:
Old 04-20-2019, 07:21   #14 (permalink)
Member: 867263
Thanks Meter: 34
try to full flash after post results.
Page generated in 0.22372 seconds with 8 queries
