Huawei y625-u32 Error : FH Configuration failed hello the problem of phone is hanging on logo and charging point problem i replace it drivers is ok but don't know what this mean coz i don't work on qlm so much not familier here Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0AF29151 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 56AEC4329D093631EE438D925D24AC9C ID_BLOCK_L : A9A46AC5B659810287765B90921D0B30 Use CM2 Internal Loader Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! |
the same problem with my handset G630-u10 Wait for phone... Device Found! Initialize ... Handshake passed! BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12] ID_BLOCK_S : 0651FC60 ID_BLOCK_I : 008140E1 ID_BLOCK_L : 659FF501AC3A27221D7282834C179FAF ID_BLOCK_L : 087BC56469F862E3E6D1BA7371BCAA91 Pickup loader from firmware package Loader Sent! Initializing ... Error : FH Configuration failed! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
and also phone not get into recovery |
Hello team i have another phone now same model problem is hang on logo and not get to recovery mode and when i solder tp point and tru to identfie by box same problem above HOW THIS MEMBER SUCESS TO FLASH PHONE http://forum.gsmhosting.com/vbb/f296...-done-2200543/ AND THIS TOO http://forum.gsmhosting.com/vbb/f296...-done-2185653/ PLZ GUID ME |
hello another phone same model y625-u32 i have xml firmware v 106 and try to flash it look to logs:: Code: Wait for phone... and by memory fail i want make sure if it is emmc or what :confused: |
In cm2qlm connect phone on EDL mode and open "memory tool" after load all partition, do right click whit mouse on any white "space" on memorytool window and you will see option check emmc, most probably your emmc are dead if get error or can't load FHLoader. |
