Old 05-06-2017, 17:32   #1 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 374
Post Huawei y625-u32 Error : FH Configuration failed
hello
the problem of phone is hanging on logo
and charging point problem i replace it
drivers is ok but don't know what this mean coz i don't work on qlm so much not familier here
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
BB_IDC_CPU : SnapDragon 2x/4x|00 [MSM8x12]
ID_BLOCK_S : 0AF29151
ID_BLOCK_I : 008140E1
ID_BLOCK_L : 56AEC4329D093631EE438D925D24AC9C
ID_BLOCK_L : A9A46AC5B659810287765B90921D0B30
Use CM2 Internal Loader
Loader Sent! Initializing ...
Error : FH Configuration failed!
Remove battery, cable. Check cable and connection. Repeat operation!
Old 05-07-2017, 04:20   #2 (permalink)
Member: 110518
Thanks Meter: 15
the same problem with my handset G630-u10
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_S : 0651FC60
ID_BLOCK_L : 659FF501AC3A27221D7282834C179FAF
ID_BLOCK_L : 087BC56469F862E3E6D1BA7371BCAA91
Pickup loader from firmware package
Reconnect Power/Cable!
Old 05-07-2017, 05:47   #3 (permalink)
helpo's Avatar
Member: 2175357
Thanks Meter: 374
and also phone not get into recovery
Old 07-05-2017, 16:36   #4 (permalink)
helpo's Avatar
Member: 2175357
Thanks Meter: 374
Hello team
i have another phone now same model problem is hang on logo and not get to recovery mode
and when i solder tp point and tru to identfie by box same problem above
HOW THIS MEMBER SUCESS TO FLASH PHONE
Huawei Y625-U32 unbrick done
AND THIS TOO
HUAWEI Y625-U32 MSM8612 Firmware Read Dead Boot Recovery Firmware Done
PLZ GUID ME
Old 05-13-2018, 18:56   #5 (permalink)
helpo's Avatar
Member: 2175357
Thanks Meter: 374
Post
hello
another phone same model y625-u32
i have xml firmware v 106
and try to flash it look to logs::
Wait for phone...
Device Found!
Initialize ...
Handshake passed!
ID_BLOCK_I : SnapDragon 2x/4x|00 [MSM8x12]
ID_BLOCK_S : 0D152162
ID_BLOCK_L : 6781FB03B23825201F749C814E159DAD
ID_BLOCK_L : CC8709A0953CAE27DA157EB7BD706E6D
ERROR : FH Configuration failed!
HINT : Remove battery, cable. Check cable and connection. Repeat operation!
the problem of phone is hang on logo
and by memory fail
i want make sure if it is emmc or what
Old 05-14-2018, 00:45   #6 (permalink)
bananin's Avatar
Member: 150844
Thanks Meter: 236
In cm2qlm connect phone on EDL mode and open "memory tool" after load all partition, do right click whit mouse on any white "space" on memorytool window and you will see option check emmc, most probably your emmc are dead if get error or can't load FHLoader.
The Following User Says Thank You to bananin For This Useful Post:
Page generated in 0.36098 seconds with 7 queries
