07-18-2019, 19:17 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: Nigeria
Member: 1677653 Status: Offline Thanks Meter: 2,769 | huawei y7 prime (2018) LDN-L21 LOADER NEEDED URGENT KINDLY HELP FOR LOADER FOR THIS DEVICE THANKS IN ADVANCE Card found : A6936825 , v0138 Infinity-Box Chinese Miracle Qualcomm Module [QLM] v 1.16 Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : ED681427 ID_BLOCK_E : 00150041 ID_BLOCK_L : 1BB6042168D9B15B6E13806A0F94F5C7 ID_BLOCK_L : 34B693D3F70C6D3EC2970DA103C748AC Use CM2 Internal Loader ERROR : Prepare target failed! Unsupported SecureType! INFO : Send log and report.log to support! Include device info also! Reconnect Power/Cable! Loading firmware ... Loading 1 program definition file(s) ... Load Ok! Operation : Identify [ v1.16 ] 1. Power Off Phone , Remove battery , Insert back 2. PRESS and HOLD BOTH VOLUME KEYS! 3. Insert USB cable. In some cases require use EDL cable or TP to force EDL mode! Wait for phone... Device Found! Initialize ... Handshake passed! ID_BLOCK_I : SnapDragon 430 [MSM8937] ID_BLOCK_S : ED681427 ID_BLOCK_E : 00150041 ID_BLOCK_L : 1BB6042168D9B15B6E13806A0F94F5C7 ID_BLOCK_L : 34B693D3F70C6D3EC2970DA103C748AC Pickup loader from firmware package FH_LOAD_CODE : 15 ERROR : Loader send failed! HINT : Check cable, connection and drivers! Reconnect Power/Cable! |
The Following User Says Thank You to Yusuf Lawal For This Useful Post: |
