Old 05-11-2017, 20:23   #1 (permalink)
Member: 1737002
Sonork: 1612611
Thanks Meter: 2
Huawey cun-l21 frp operation failed
hi I can not do frp Hlp please
Chinese Miracle II  [MTK module] v 1.58
Operation : Format FileSystem [ v1.58 ]
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BB_CPU_NME : [MediaTek] MT6735_S00
Processing BROM stage
Settings for BROM configured!
SecCfgVal : 0x00000000
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Sending and initialize DA ...
[DA_ERROR] : SECURITYBOOT_BOOT_NOT_ACCEPTED
Boot Error!
Operation Failed
Elapsed: 00:00:11
Reconnect Power/Cable!
Old 05-12-2017, 18:28   #2 (permalink)
Member: 1737002
Sonork: 1612611
Thanks Meter: 2
I can read the full flash... access to the desktop is already there ... and settings, but to remove google account can't
Help team!!
Old 09-13-2017, 08:42   #3 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 128
Same problem
Need FRP remove for Huawei CUN-L21
Old 09-13-2017, 08:56   #4 (permalink)
Member: 1578597
Thanks Meter: 31
https://www.youtube.com/watch?v=m35-LQ5NALE
Old 09-13-2017, 13:05   #5 (permalink)
Abzal's Avatar
Member: 19032
Thanks Meter: 128
in my case work only this method
https://www.youtube.com/watch?v=jjrpcmMpkVU
all 3 files in one place
https://yadi.sk/d/FNvBeIUH3MrBFG
Old 09-13-2017, 13:32   #6 (permalink)
sky73's Avatar
Member: 1876736
Thanks Meter: 343
Change da file team long time said how
If you dont have it pm me
Old 09-13-2017, 14:01   #7 (permalink)
Member: 1143383
Thanks Meter: 29
I think the Infinity CM2 project is going through its last days. Like several other projects where more updates, more innovations and no mediatisation.
If you want to work without problems on smartphones at cpu Mediatek, go to NCK BOX.
Old 09-13-2017, 14:13   #8 (permalink)
Member: 1988630
Sonork: 100.1664547
Thanks Meter: 295
Wait for phone...
Phone found! [ 17 ]
Sync...
Inital Boot Ok!
BB_CPU_PID : 6735
BromVer   : 0x00FF
BLVersion : 0x0001
Processing DA stage
Boot Error!
Operation Failed
Elapsed: 00:00:11
Boot loader lock so need secro boot img then flash by tool then unlock frp if you dont have secro boot for this model also by pass by this method without box
Method 2
Old 09-13-2017, 15:49   #9 (permalink)
Member: 1143383
Thanks Meter: 29
It is supported on NCK BOX. 100% Ok. Tested by Me.
Old 09-14-2017, 14:01   #10 (permalink)
Member: 1988630
Sonork: 100.1664547
Thanks Meter: 295
this is infinity-box section not xck so i dont need xck. infinity better to xck...
Old 08-04-2018, 14:03   #11 (permalink)
AhMed Himel's Avatar
Member: 2780773
Thanks Meter: 111
cm2 secure boot Huawei Cun L21 CM2 Boot Error Solution Read Write Done
https://www.youtube.com/watch?v=RTlzfUeb0HM
The Following User Says Thank You to AhMed Himel For This Useful Post:
Page generated in 0.27177 seconds with 7 queries
