06-25-2010, 21:05 | #1 (permalink) |
Freak Poster Join Date: Sep 2007
Member: 593061 Status: Offline Thanks Meter: 19 | Huawey g6610 cant connect COM6 [VCP0] selected module v3.46 Action: read unlock codes unlock method: read codes Model: Huawei-G6610 Checking data, wait... Phone should be Switched OFF ! Press and HOLD Power button now ! error: can't activate test mode error: operation failed ! Finished, time used: 7 sec Remove/Install battery now ! |
06-27-2010, 15:52 | #2 (permalink) | |
it's for sure cable problem. Please, double check your cable/pinout. | |
06-27-2010, 20:20 | #3 (permalink) |
No Life Poster Join Date: Apr 2006 Location: Cuba-Holguin
Member: 256260 Status: Offline Thanks Meter: 726 | for connect ok but unlock no work in this vertion please support this vertion look the log COM7 [VCP0] selected module v3.45 Device: Huawei-G6610 Checking data, wait... advanced flash detection enabled Action: "sp-unlock" unlock method: standard ffs/eeprom backup enabled, it may takes several minutes ! ====> Boot ... Press and HOLD Power button now ! 19200 fixed Connecting, wait... Initializing [6225:8A05:8A00]... CPU: MT6225 chip: 0001:F203:0008 status: FF boot packet size: 0400 Release Power button now ! Boot Done ====> Initialize ... detecting chip #00 in region #00... flash: EC227E22632260:0AEA0000000000 flash: AMD/Fujitsu std [D 0004x010000 007Ex040000 0004x010000] 32Mb otp offset: 00000000 number of flash chip/regions detected: 01/01 Initialize Done ====> Set baud ... 921600 Set baud Done ====> Initialize bootcode ... Initialize bootcode Done ====> Check firmware integrity ... usb bootloader detect... usb bootloader (chip) is present: 00010000 searching rom info... search rom info finished rom info structure: 2nd [standard] generation TCL-ID is absent rom info detection finished ==================== New firmware detected (v.3.45, database date: 20.06.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_ SS_MN_P63_I308_04_11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_ SS_MN_P63_I308_04_11.BIN project-id: G6610.CA.SS.MN.P63.I308.04.11, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... . search sec info#1 finished Check firmware integrity Done ====> Check firmware content ... Check firmware content Done ====> Backup required data ... reading: Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G66 10_CA_SS_MN_P63_I308_04_11__ffs... file saved: C:\Archivos de programa\InfinityBox\MModule\Huawei-G6610_TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G66 10_CA_SS_MN_P63_I308_04_11__ffs_20100622-095810.B0E.bin flash: EC227E22632260:0AEA0000000000 Backup required data Done ====> Patch required data ... detection procedure, wait... detection procedure completed detection procedure, wait... error: phone is not locked or unknown eeprom Patch required data Done ====> Special operation ... detecting parameters to apply patch area 1... .................................................. .................................................. ............................ error: area 1 can not apply patch detecting parameters to apply patch area 2... .................................................. .................................................. ............................ error: area 2 can not apply patch Special operation Done ====> Write ... flash: EC227E22632260:0AEA0000000000 Write: ffs Write Done ====> Finalization ... Finalization Done Finished, time used: 5 min 40 sec Remove/Install battery now ! |
The Following User Says Thank You to Yaio For This Useful Post: |
06-30-2010, 15:26 | #9 (permalink) |
Member: 256260 Status: Offline Thanks Meter: 726 | no unlock and read codes in this firmware vertion New firmware detected (v.3.45, database date: 20.06.2010): TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_ SS_MN_P63_I308_04_11.BIN This firmware is missing in support area. If this phone is good and working: - download latest software from support area and try again, probably this firmware already supported in latest software - make "Read full flash" operation - send flash backup files to support: [email protected] or upload files to RapidShare: 1-CLICK Web hosting - Easy Filehosting or 4shared.com - free file sharing and storage - include in your e-mail full text from phone back label (phone name etc.) ==================== rom info ver: 05 sw version: TINNO25_08A_GEMINI_PCB01_GPRS_MT6225_S00.G6610_CA_ SS_MN_P63_I308_04_11.BIN project-id: G6610.CA.SS.MN.P63.I308.04.11, 00000000 code offset: 00010000 ffs offset/size [01]: 01C00000/003F0000 rom info structure: 2nd [standard] generation TCL-ID is absent ffs/eeprom address assigned: 01C00000 sec info (detailed) detection... searching sec info#1... Last edited by Yaio; 06-30-2010 at 15:34. |
07-01-2010, 19:02 | #12 (permalink) |
Member: 593061 Status: Offline Thanks Meter: 19 | my cable is ok i use this for alcatel, with pinfinder dont work with pinout alcatel, dont connect, i have tested with 4 new phones and no connect Note: Before i can flash, read user code for g6610 , and after update module cant connect |
07-01-2010, 19:52 | #13 (permalink) | |
No Life Poster Join Date: Oct 2005 Location: .:Planet Namek:.
Member: 189984 Status: Offline Thanks Meter: 112 | Quote:
or maybe check this post... http://forum.gsmhosting.com/vbb/f296...d-here-495969/ | |
07-01-2010, 20:12 | #14 (permalink) | |
Member: 593061 Status: Offline Thanks Meter: 19 | Quote:
07-01-2010, 21:06 | #15 (permalink) |
Member: 189984 Status: Offline Thanks Meter: 112 | little faith man, connector 2x5 1 2 3 4 5 6 7 8 9 10 4: phone Tx 5: phone rx 6: Gnd [IMG]http://www.************/forum/uploads/monthly_01_2010/post-71370-1263410709.jpg[/IMG] pinfinder cable L10B |
The Following 4 Users Say Thank You to samusprime For This Useful Post: |
Connecting To Phone | jscoulter | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-20-2000 11:03 |
cant unlock CSI eeprom | Stryker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 08-20-2000 13:00 |
How to use Nokia tool - with connection 6-7 pin or not?.. | 2M | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-20-2000 19:53 |
WE OFFER cables for connection cellular-phones to the computers | GLEBUS | Main Sales Section | 0 | 06-04-2000 19:05 |
Nokia Datasuite Connection Failure | Judesp | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-27-1999 09:36 |
