08-04-2017, 18:33 | #1 (permalink) |
No Life Poster Join Date: Sep 2006 Location: Allah is Greatest
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Hurricane Freedom Dead After Flash after complete flash now its dead. I try to connect it with pc but not luck. I connect it with normal and holding volume bottons . Then i try to connect KCOLO and KCOL1 with GND. but same . Please tell me what to do. On board it showing MT8312CA But at info it showing MT6572. I used this firmware to flash. Hurrican Freedom 3g MT6572 100% (celltech-+263785525466) Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0x2003 EMICFG_NOT_FOUND TRY NOT HOLD VOLUME(+/-) KEYS ON CONNECT! Boot Error! Operation Failed Elapsed: 00:00:15 Reconnect Power/Cable! Flashing Log Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 36 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x0005 BLVersion : 0x00FE PreLoader : NOT Active [ Erased ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... [DA_ERROR] : DRAM Configure failed! ErroCode : 0xBE0B0000 EMICFG_RET_FAILED CodeDefine : DA_DRAMC_RANK0_CALIBRATION_FAILED Boot Error! Operation Failed Elapsed: 00:00:24 Reconnect Power/Cable! |
08-04-2017, 18:41 | #2 (permalink) |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Log Before Flashing. Start at : [8/4/2017 / 9:47:25 AM] Operation : Check / Read Info [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 544 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642043FCCE3D60A2D3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB] DEV RID : 0xBF15704B4FD899C25BF15D4A96D67302 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! [AP] : Initial info read Ok! Brand : alps ProdName : Hurricane ProdModel : Freedom Device : Hurricane AndroidVer: 4.4.2 MTKxCPU : MT6572 MTKxPRJ : ALPS.KK1.MP7.V1.44 SECURITY : IMEI_SW [1] : 868254022870343 IMEI_SW [2] : 868254022870350 BTMAC Addr : 54EF92FACE3C WiFi MAC : 54EF92B477B6 MODEM : BaseBand : MT6572_S00_MOLY_WR8_W1315_MD_WG_MP_V72_1_wg_n EXTRA : LCD [0] : tf070mc124_dsi LCD Res : 1024x600 TOUCH [0] : gslX688 CAM [0] : s5k4ecgx_yuv CAM [1] : gc2035_yuv CAM [2] : gc2155_yuv CAM [3] : gc2145_yuv CAM [4] : bf3920_yuv CAM [5] : gc0328_yuv CAM [6] : gc0308_yuv CAM [7] : gc0329_yuv CAM [8] : gc0311_yuv CAM [9] : gc0312_yuv CAM [10] : bf3a03_yuv CAM [11] : bf3703_yuv MODEM : elink12c_w2_hspa LOCALE : en_US af_ZA am_ET ar_EG ar_IL bg_BG bn_IN ca_ES cs_CZ da_DK de_AT de_CH de_DE de_LI el_GR en_AU en_CA en_GB en_IE en_IN en_NZ en_SG en_ZA es_ES fa_IR fi_FI fr_BE fr_CA fr_CH fr_FR hi_IN hr_HR hu_HU in_ID it_CH it_IT iw_IL ja_JP km_KH ko_KR lt_LT lv_LV ms_MY my_MM nb_NO nl_BE nl_NL pl_PL pt_BR pt_PT rm_CH ro_RO ru_RU sk_SK sl_SI sr_RS sv_SE sw_TZ th_TH tl_PH tr_TR uk_UA ur_PK vi_VN zh_CN zh_TW zu_ZA Done! Elapsed: 00:00:08 Reconnect Power/Cable! Finish at : [8/4/2017 / 9:47:34 AM] Start at : [8/4/2017 / 9:48:27 AM] Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 544 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642043FCCE3D60A2D3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB] DEV RID : 0xBF15704B4FD899C25BF15D4A96D67302 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Clear USERDATA Clear Ok! Clear CACHE Clear Ok! Done! Elapsed: 00:00:22 Reconnect Power/Cable! Finish at : [8/4/2017 / 9:48:50 AM] ========================= Start ========================= 8/4/2017 / 11:28:36 AM ================================================== ======= Card found : S/N : C7434459 , v0136 Chinese Miracle II [MTK module] v 1.58 Scatter Load Ok , BaseBand : MT6572 , Project : nck_team , Storage : EMMC Files found : 11 , Set to Flash : 10 Ready to Flash! Start at : [8/4/2017 / 11:29:48 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 544 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642043FCCE3D60A2D3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB] DEV RID : 0xBF15704B4FD899C25BF15D4A96D67302 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : nck_team , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! Operation Failed Elapsed: 00:00:11 Reconnect Power/Cable! Finish at : [8/4/2017 / 11:29:58 AM] Start at : [8/4/2017 / 11:30:46 AM] Operation : Flash [ v1.58 ] ======= Flash 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey Wait for phone... Phone found! [ 544 ] Sync... Inital Boot Ok! BB_CPU_PID : 6572 BB_CPU_NME : [MediaTek] MT6572_S00 BB_CPU_EXT : 0xCA01 , 0x8A00 , 0x0000 Processing BROM stage Settings for BROM configured! SecCfgVal : 0x00000000 BromVer : 0x00FF BLVersion : 0x0001 PreLoader : Active [ Boot with PL ] BootLdrSS : NORMAL with PRELOADER Processing DA stage DA Select done, will use MTK_AllInOne_DA_v5.1624.16.07 Sending and initialize DA ... Running DA ver.4.2 on BBID : 0x88 NAND Flash : NOT INSTALLED eMMC Flash : 8801034E436172642043FCCE3D60A2D3 Initialize Memory ... DRAM already initialized by Preloader DAgent sent , init HW now eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0x88 , OEM : 0103 [eMMC] : FLASH_INF : [FORESEE] , draC [eMMC] : FLASH_CID : 8801034E436172642043FCCE3D60A2D3 [eMMC] : FLASH_BRT : 0x00400000 , 0x00400000 , 0x00020000 [eMMC] : FLASH_LEN : 0x00000000E7400000 [eMMC] : FLASH_UCP : 3700 MiB [eMMC 4 GiB] DEV RID : 0xBF15704B4FD899C25BF15D4A96D67302 INT RAM : 0x00020000 EXT RAM : 0x20000000 [512 MiB] BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! ScatCFG : BaseBand : MT6572 , Project : nck_team , Storage : EMMC Setting : Flash Pre-Erase (Safe) : Enabled Setting : AFF verify : Enabled Setting : HW verify : Enabled BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! BL : BatteryLevel : 3686 mV BL : BatteryLevel Ok BL : Flash Pre-Erase Total blocks to Erase : 2 Erase : 0x0000000000A00000-0x0000000000100000 Erase : 0x0000000002700000-0x00000000E4020000 Flash Pre-Erase Done, time used : 00:00:01 SecCfg Passed , 1799 BMT remark not need. Will skip Preloader Download skipped by user request! PartCount : 0012 Update PMT by user request Repartition Done! Use FLN Mode Processing : Flash Write Flash now : MBR Image Flash Ok Flash now : EBR1 Image Flash Ok Flash now : PRO_INFO Write Error , code 0x000! Something went wrong! Operation Failed Elapsed: 00:00:13 Reconnect Power/Cable! Finish at : [8/4/2017 / 11:30:58 AM] |
08-04-2017, 22:25 | #3 (permalink) |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Skip checking by User request! right here...why do you untick this button? now you cry cry cry...you killed your mobile by yourself... BL : Check HW compatibility BL : BBID supported by BootLoader! BL : Check eMMC compatibility BL : eMMC NOT supported by BootLoader! [BL_ERROR] : STORAGE : Break Flashing! This Firmware will kill phone! the software warned your but you did not listen...try finding the right firmware for your phone AND NEXT TIME ALWYS BACKUP FIRMWARE BEFORE OPERATION |
The Following User Says Thank You to nessyb For This Useful Post: |
08-05-2017, 20:55 | #4 (permalink) | |
Member: 358694 Status: Offline Sonork: 100.1597323 Thanks Meter: 994 | Quote:
