01-06-2016, 18:45 | #3 (permalink) |
No Life Poster Join Date: Oct 2005 Location: Pakistan
Member: 192810 Status: Offline Sonork: Some people NEED change Thanks Meter: 860 | I have Uploaded Plz check it. CX_SPDNV - Download - 4shared Code: Operation : Check/Read Info [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FLASH : eMMC Flash , Structure : Ok! Reading extended info ... Model Name : Y541-U02 Model Brand : HUAWEI Model Device: HWY541-U AndrVersion : 4.4.2 BaseBand CPU: Y541-U02 CompileDate : 1435575104 Project Ver : Y541-U02V100R001C567B109 Model Ext : HUAWEI Y541-U02 ExtraInfo : HWInfo not exists, normal phone ExtraInfo : GSM Phone Elapsed: 00:00:51 Reconnect Power/Cable! Operation : Read FullFlash [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! FlashMode Set : Ok! Detected eMMC Flash , Structure detect Ok! [FW_READER] : Step #1 Passed! [FW_READER] : Step #2 Passed! [FW_READER] : Step #3 Failed! Error_Info : DVL Failed , If it Android 5.x - Root Required :( Operation : Read NV [ v1.11 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 9 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable FDL Ready! Boot Ver : Spreadtrum Boot Block version 1.1 Sending FLASH FDL FLASH FDL Ready! Boot Ok! Detected eMMC Flash , Structure detect Ok! Read NVM Part #1 Part Ok Read NVM Part #2 Part Ok Saved to : C:\Users\DUNIYA JAMAL\Desktop\Huawei Y541-U02\CX_SPDNV.spdnv Elapsed: 00:01:00 Reconnect Power/Cable! |
01-09-2016, 09:09 | #7 (permalink) |
Registered User Join Date: Feb 2008 Location: andhra pradesh
Member: 702331 Status: Offline Thanks Meter: 61 | i flashed this phone with sd update but after flash no signal and i try to boot with all possible cpus in cm2 but not booting here is the log Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable ========================= Start ========================= 1/8/2016 / 6:15:52 PM ================================================== ======= Chinese Miracle II [SPD module] v 1.09 Start at : [1/8/2016 / 6:16:12 PM] Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! Finish at : [1/8/2016 / 6:16:37 PM] Start at : [1/8/2016 / 6:16:47 PM] Operation : Read FullFlash [ v1.09 ] 1. Remove battery. Insert battery back 2. Press and hold 'VolumeUp' and 'VolumeDown' keys 3. Insert cable ==== Wait for phone... Phone found! [ 20 ] Port Opened Sync... InitBoot Done [ 0x81 ] , Ver : SPRD3 Sync... Sending FDL [Info] : If SW freeze here more, than 15 seconds - remove cable Boot failed! Loader start failed! Wrong Model selection! Boot failed! Reconnect Power/Cable! |
11-08-2016, 02:16 | #10 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | cm2 wont unlock such phone it says phone is aready unlocked, nothing to do. but phone is locked, it is locked by firmware. fimware needs to be patched on this phone. |
