12-31-2015, 19:57 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: Pakistan Lower Dir kpk
Member: 651892 Status: Offline Thanks Meter: 205 | ZTE Blade L2 unlock problem cm2 read 8 digits code but phone asking for at least 12 digits code here is log of direct unlock phone unlocked but no network..(emergency call working ok) |
01-02-2016, 15:25 | #3 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. I need some help with it. Can't find such sample at my area. If you can readout first 64 MiB of flash ( 0 : 4000000 ) and send me in PM for further check - will try. Currently work on new mwthods of direct unlock for SP. |
01-04-2016, 08:59 | #7 (permalink) |
No Life Poster Join Date: Jul 2014 Location: Nowshera
Member: 2217500 Status: Offline Sonork: 100.1597179 Thanks Meter: 326 | Wait for phone... Phone found! [ 11 ] Sync... Inital regs read done Boot Info : BB_CPU_ID : 6582 BB_CPU_HW : CA01 BB_CPU_SW : 8A00 BB_CPU_SB : 0001 BB_CPU_NM : [MediaTek] MT6582_S00 Processing BROM stage SecCfgVal : 0x00000000 BromVersion : 0xFF BLVersion : 0x01 Preloader Status : Alive Processing DA stage DA Select done , sending DA Ver : MTK_AllInOne_DA_v5.1540.01.01 NAND_ID : 00000000000000000000000000000000 eMMC_ID : 90014A4834473164048602A40BEF913D DA Stat : v4.2 on BBID : 0x87 DA Sent. Configure setting now ... DA started successuflly eMMC FlashIC initialized [eMMC] : FLASH_VEN : 0090 , OEM : 014A [eMMC] : FLASH_INF : [HYNIX] , d1G4 [eMMC] : FLASH_CID : 90014A4834473164048602A40BEF913D [eMMC] : FLASH_EXT : 0x00200000 , 0x00200000 , 0x00200000 [eMMC] : FLASH_LEN : 0x00000000E7000000 [eMMC] : FLASH_UCP : 3696 MiB INT RAM : 0x00020000 EXT RAM : 0x40000000 BOOT TYPE : EMMC_FLASH_BOOT SOC VERIFY : C1 Boot Ok! Lock Status : Locked! Unlocking ... Unlock done! |
05-13-2017, 07:46 | #9 (permalink) |
Junior Member Join Date: Nov 2013
Member: 2064614 Status: Offline Thanks Meter: 5 | nvram nvram zte blade l2 100% ok https://drive.google.com/drive/u/0/my-drive Last edited by LIMIX; 05-13-2017 at 07:55. |
05-13-2017, 08:16 | #10 (permalink) |
Member: 2064614 Status: Offline Thanks Meter: 5 | [QUOTE=LIMIX;12496827]nvram zte blade l2 100% ok https://drive.google.com/file/d/0Bx-...ew?usp=sharing |
The Following User Says Thank You to LIMIX For This Useful Post: |
